stock speaker size
Old Aug 29, 2006 | 07:03 PM
scoob2evo's Avatar
stock speaker size
for front and rear... anyone know off the tops of their heads
Old Aug 29, 2006 | 09:11 PM
9GUY9's Avatar
6.5" for all 4.
Old Aug 29, 2006 | 09:18 PM
evo/X's Avatar
is it jl or jbl that makes a sick W7 10 in sub???
Old Aug 29, 2006 | 09:20 PM
9GUY9's Avatar
JL makes the W series subs. Their supposed to be pretty good.
Old Aug 29, 2006 | 09:22 PM
TogueMonster's Avatar
Theyre not pretty good. Theyre the best! Been using JL Audio since high school. That was a very long time ago
Old Aug 29, 2006 | 09:27 PM
9GUY9's Avatar
Ok
I am very happy with my image Dynamics ID Max12. but I have 0 experience with JL.
Old Aug 29, 2006 | 09:34 PM
evo/X's Avatar
the jl w 7 or whatever will hit about the same as sayyy two 12'' .....fact..... and with a quarter of the weight...ideal for an evo
Old Aug 29, 2006 | 09:39 PM
ApexVIII's Avatar
would there be any point to add 2 6x9s in the trunk in the same box as 1 10"? or would there be no piont
Old Aug 29, 2006 | 09:41 PM
No that would be useless. You never put different size speakers in the same box. It doesnt work that way. Plus if you use 6x9's in the trunk you wouldnt be able to hear the higher frequencies. Just say no.
Old Aug 29, 2006 | 09:42 PM
9GUY9's Avatar
no, you would probably loose much more than you would gain. If your going to run a real sub don't mess with 6X9"s. Just put the stock sized 6.5" speakers in the stock locations.
Old Aug 29, 2006 | 09:47 PM
evo/X's Avatar
imo i would repleace the six stock speakers(if need be) then put a sub in youre trunk and be sure to bolt it down with some metal L's.
Old Aug 30, 2006 | 01:48 AM
DontRevMe's Avatar
No single 12 can move anywhere near as much air as 2 12"s... So not fact.
I work for the largest JL retailer in the nation, and even i outsourced for Image Dynamics woofers.
Old Aug 30, 2006 | 04:14 PM
mitsuatb's Avatar
Fyi
6 1/2 and 6 3/4 will not fit without some sort of adapter.
The guy on ebay has good adapters, the acutal size seems to be a 7" european Din size.
Mitsuatb
Old Aug 30, 2006 | 07:29 PM
SpinOne05's Avatar
+1 for that. No replacement for displacement. In some home and car applications people use a 'passive radiator'. It's kinda like a subwoofer that is not powered and is there to move more air which means more SPL(sound pressure level) which is good for bass. Go big and get 3 jl 12w6v2 for high SPL and good sound quality.
Old Aug 30, 2006 | 07:46 PM
evo4g63awd's Avatar
get a good set of 6 1/2" components for the front, you wont hear the rear speakers as much as the fronts.
JL makes very good subs, and amps! all depends if you can afford it....
