New Audio Stuff w/ pics
I initially went with Sirius as well but the reception was horrible no matter where I put the antenna. Did you have any problems with yours?
BTW - I now have XM and great reception...
I don't have any reception issues. I will be going to get tint in a few days but they don't tint where the 3rd brake light is so that won't be a problem. Also I finished up my mount for the s50 and will post pics alittle later. Also I am thinking about moving the mic to the dash behind the HVAC grill like previously mentioned so I will update with that as well.
Here is the finished S50 mount this is my first attempt at trying to actually make something like this so bear that in mind.
Here is the final product I went ahead and swapped the gauges w/ the radio and moved the boost gauge over. Also, most people have trouble getting the trim ring for their aftermarket radios on. If you put the radio in the bottom cubby then all you need to do is drill new holes where the indention are on the stock radio mount and then the trim goes on and looks perfect. If you keep it in the top then it will stick to far out with this method. Someone mention using 3 washers on each of the ears to get in right in the top hole.
Here is the pics.
Here is the pics.
clean set up bro.. just did my audio / video set up too.. will post pics..
