Sub mounting options (IX)
Old Oct 22, 2006 | 11:38 PM
FunkyR's Avatar
Hi guys, tried a search with not much luck.
Any ideas how to mount a sub in the boot of the IX with a rear strut bar?
Not interested in fiber glass inserts etc....
Thanks!
Old Oct 23, 2006 | 05:10 AM
3SgteGuru's Avatar
custom box with like some 10" subs. You can make it deep though. Angle the woofer so the box is shorter, it will look pretty hot. I know you can think of something, post pics to help other people after your done.
Old Oct 30, 2006 | 04:04 PM
jdub765's Avatar
If you don't mind messing up the strut bar, make a box with the bar passing through it. You could fiberglass the bar into the box, or if you don't want to mess up the bar, build a tunnel through the box, or fiberglass a thick-walled PVC pipe into the box to use as a tunnel. Or you could build in a notch in the box for the strut bar. Or if you know how to build the box strong enough and brace the inside enough, you could make a custom strut bar that mounts to either side of the box and uses the box as a structural part of the strut bar. Just be creative =)
Old Oct 30, 2006 | 04:19 PM
lightspeed1's Avatar
FWIW I ran into a problem the same as you... I am in the process of making a resolve to this situation of sub box fitting issues. If you would like to pm me next week I should have it available for viewing... Hang in there I have the problem solved!! Next week...
Old Oct 30, 2006 | 04:21 PM
icedomin8r's Avatar
Be a man, glass in a box in the rear right or left side of the trunk.
