specs for the interior stock speakers?
guys i was wondering if anybody knew the stock specs for the speakers of the 05 evo8 gsr .....i want to upgrade my front interior speakers but whats the size? 6.5? ....i think they are five and a half? ....please reply. thanks in advance....also does anybody know what the RMS for them are...because they handle nicely so far...but i want to go and upgrade them since i went out and got a ridiculus bass set up now....
Most 6.5" woofers fit the doors. Use crutchfield's website to find out what fits. I have 6.5" Alpine SPX-177A in the doors and they fit perfectly. I have the 137A, which are 5.25", in the rear custom fitted. I'm sure the 6.5" will fit the rear but i haven't tested.
-George
-George
oh...because i want to instal some 6.5 MA audio here are the specs
6.5” Bi-Ampable Component System
100W RMS Power Handling
200W Peak Power handling
Bi-Ampable Crossover (Dual Amplifier Inputs)
Balanced 12dB Crossover
2-Layer High Temp Kapton Voice Coil
10oz. Strontium Magnet for Optimum Performance
PEI Titanium Tweeter
Mica Cone for Clean Sound Reproduction
4 Ohm Impedance
Sensitivity: 90.6dB @ 1w/1m
Frequency Response: 30 Hz - 25 kHz
Mounting Depth: 3”
so i wanted to know if the depth of the door would fit these...since its a 3in mounting dept...and at 100rms for interiro voices...it will b loud enough to keep up with the bass setup i have going.....btw since u took out the stock speakers...do u know the watts/rms of the stock speakers?
4 Ohm Impedance
Mounting Depth: 3”
3" is pretty deep, but will most likely fit if you use any kind of mounting ring. I have Alpine SPX-177R 6.5" seperates in the front, and the woofer has a 2.8" mounting depth. I used speaker adapter rings with a base-ring of dynamat on the door hole, then the adapter-ring, then a dynamat ring between the adapter-ring and the speaker. No problems rubbing on the glass when down, and the face clears the door panel grill. Had I not used the dnamat-adapter sandwitch, the magnet would have rubbed on the glass when down in my case.
hmmm where did you get the dynamat rings.....and it seems they are needed for a 3in mounting dept then........for ur set up..did you use your inside spekers with bass or like me ....im just using my interior spekers for voices only no bass at all....i have x-over/eQ for tuning the system....and all equipment is competition specs...after i finish the set up i will post up the specs of my gear.....but oh..and do you remember what the watts said on the stock speakers? it should have said on the back of the magnet
Post your system list up when you can. It's always good to see what goodies other people have chosen.
man for 15w rms at 4 ohms they handle nicely....yeah i have a touchscreen also....not too good with tuning but thats why i went out and got external x-over and Eq.....question i had was....the adaptor rings should come with the speakers...or did u end up getting others? and i will test the window down for clearance and fitment.
you mentioned you had a "drain set up" before....how are you now? are u using caps? what did you do to fix the problem...i have when my lights surge like a mF. ...another member on here talked about addint the fuses on ur amps...interior/sub amps and then adding 50 more cause u need 50 amps to make the car run...and then you have the amount of amps for the alternator to run perfect.....but i asked him why not use a secondary battery...imo Optima Yellow top...880 amps thats plenty. a friend of mine had the alternator dead but the battery still started up his car and ran perfectly.....did you use caps?
How much mounting depth do we exactly have in the front doors of our evo's? The speaker's im looking at are around 2.5" and I want to know if they'll fit without rings and adapters and what not.
well, the ones i have that i have not mounted up yet because im still waiting on a more powerfull amp to power them has not arrived yet. well mines are 2.75 with out the dome....and a buddy of mine had 3 inch mounted and we had to dremel some of the backing parck of the door...no harm done...sorry i havent updated none of this but i got in an accident and now im in the progress of dealing with insurance and getting my car fixed....any questions just post them up...im sure i if not others will respond....
