Amp Locations
Old Feb 18, 2007 | 10:54 PM
ntwaddel's Avatar
Amp Locations
Where have you guys mounted your amps?
Old Feb 18, 2007 | 11:53 PM
spyderx's Avatar
on my viii and going on my ix, bolting up two amps on the "V" stock brace of the trunk thru panel. You'll see it when you take the cover off. Measure and drill for vertical installs. Frees up a lot of room on the trunk floor. I then put back the rear strut bar which act as barrier against damage to the amps.
when you bolt up the amps, pre drill the brace and the carpeted cover. Put back the cover then bolt the amps for clean install. You can snake all the wiring to the trunk corner from interior flooring.
I'll have to post the pics when I'm finally done. It's taking forever!!!
BTW, make sure you pick lighter amps! I got two Eclipse newer amps. Small footprint and light!
Old Feb 19, 2007 | 12:11 AM
Inprogress's Avatar
Please do post pics spyderx, I'ld like to see what you did.
Old Feb 19, 2007 | 12:55 AM
DontRevMe's Avatar
Old Feb 19, 2007 | 05:59 AM
kmcconn9's Avatar
under the front seats for ease of install and looks...
Old Feb 19, 2007 | 06:04 AM
tuning g's Avatar
under the front seat there is a lot of space and easy to work in that area
Old Feb 19, 2007 | 11:23 AM
SilvrEvoIX's Avatar
^ I also got'em under the seats. It's nice to have 1000 watts under my *** and 600 watts under my girls ***!
Old Feb 19, 2007 | 08:09 PM
spyderx's Avatar
Same style install like the pic above, except I have two amps.
Old Feb 20, 2007 | 03:21 PM
Oracle1's Avatar
box is 26L and only weighs 4kg.
Attached Thumbnails Amp Locations-copy-misc-023.jpg   Amp Locations-copy-misc-042.jpg
Old Feb 20, 2007 | 07:02 PM
BennyEvo's Avatar
On my first system i had them on both sidez of my trunk, on my second system after they stole my first one i did it custom i got a foot and a half of trunk space but it lookz good and soundz real good i'll post pictures when i got some time!
You guyz also gotta remember when you got your ampz covered up your not letting any ventilation into them and they get hot and don't respond the right way.
Old Feb 20, 2007 | 07:35 PM
DontRevMe's Avatar
two words homie
zip ties
Old Feb 20, 2007 | 07:37 PM
trjx24's Avatar
i mounted my amp onto my sub box.. i like the way it looks i can post pics up on fri if u want..
Old Feb 21, 2007 | 11:31 AM
Oracle1's Avatar
Originally Posted by DontRevMe
two words homie
zip ties
I've bolted it from the front (2 bolts) and also 3 brackets at the rear (top of box) onto support underneath parcel shelf (I think OEM strut brace), afterall this car can cornor fast
Attached Thumbnails Amp Locations-evo2007-029.jpg   Amp Locations-copy-evo2007-008.jpg
Old Feb 21, 2007 | 11:36 AM
Oracle1's Avatar
:d
Old Feb 24, 2007 | 10:59 AM
evo4g63awd's Avatar
ive got my amps mounted like this
still not done yet, i made a cover for them that you can see on my post below of my system as i am working on it....
https://www.evolutionm.net/forums/sh...d.php?t=226721
