how do you bring down voltage on pioneer z1 installation
Old Mar 13, 2007 | 05:54 PM
johnleefd's Avatar
i have read that i should be at 12v, but i am at 14.6 right now. i think this is why i have constant buzz and i hear a click or a pop every time i turn my engine off.
how do i bring down the voltage? does it have anything to do with the mounting?
i spliced the rca cables, is this why i have a constant buzz and clicks and pops?
someone please tell me how i can get rid of this sound.
Old Mar 13, 2007 | 07:58 PM
cladden's Avatar
Do you have any DC-AC power converters? Transformers are very noisy.
Also , check that your radio power wires are not running near any fast switching, high voltage/high current devices like injector wires, coil wires, etc.
I'm sure its not the 14.2 volts that's causing the problem, more likely noise is getting into your system somehow -bad connections?
Old Mar 25, 2007 | 05:12 PM
knuckle's Avatar
is the gray fuse/noise filter still on the yellow power wire? it could also be a bad ground.
Old Mar 25, 2007 | 05:25 PM
sikrsix's Avatar
Or the fact that you spliced RCA'a .. Why would yo udo that? Couldnt spare the $15 max in the correct cables and connectors?
Old Mar 30, 2007 | 02:42 PM
felickz's Avatar
LOL...
12v in car electronics pretty much means somewhere around 14.4 volts
In fact the amp will sound worse at 12 volts than at 14v.
Old Aug 12, 2007 | 11:07 AM
darqnez's Avatar
The buzzing is either a ground loop or something else, you do not want to lower the voltage.
evo8426
Site Feedback / Suggestions
23
May 14, 2016 08:57 AM
dudemeister
Lancer Troubleshooting
Jan 18, 2011 10:51 PM
TrackDays
Sep 20, 2009 05:29 AM
FloopyDisk
Mar 1, 2008 11:25 AM
urbanknight
14
Dec 6, 2002 01:03 AM
