Yet another MITAH and SSL question/problem
Old Apr 22, 2007 | 04:34 PM
Spoonierme's Avatar
Okay, I did a search and found a WHOLE butt load of things that dont answer my question so i figure i'm unique.
I have an evo8 w/SSL
I installed a new aftermarket HU and used the MITAH cable. Plugged the RCA's off the MITAH to the front 2 RCA's and rear 2 RCA's slots of the HU and just left the subwoofer RCA's from the radio not connected. I'm assuming that the entire stock infinity system goes to one amp.
All inside speakers are working except the stock sub. I tested fades and balances, all are working correct, but nothing comes out of the sub.
I highly doubt that the subwoofer function on the HU makes a difference but i jacked that up anyways. Nothing.
Any ideas?
Old Apr 22, 2007 | 04:58 PM
Guyver's Avatar
Did you do anything with the blue wire from the mitah adapter? I believe that it needs to be soldered to the blue/white - amp turn on wire on the stereo harness, or the sub will not work.
Old Apr 22, 2007 | 05:32 PM
Spoonierme's Avatar
yea, i connected it with the remote cable off the head unit.
I initially thought that may be the cause but isnt the sub and speakers being powered by the one amp under the driver seat?
If the speakers work but not the sub, i'm assuming that the amp is on and the blue/remote connection is good
Old Apr 22, 2007 | 06:23 PM
Guyver's Avatar
Just for clarification, did you just hook up the mitah adapter? 2 adapters are required, 1 mitah and one mitsubishi installation harness BHA7001.
Old Apr 22, 2007 | 06:48 PM
Spoonierme's Avatar
Yes, when i got the mitah cable, it came with the harness. So i did hook up both.
I've installed several aftermarket HU on several cars, but never needed something like the MITAH cable and i might have done something wrong this time.
Old Apr 22, 2007 | 08:31 PM
atombomb33's Avatar
EvoM Community Team
That's weird. I used the MITAH and METRA (power adaptor) and it works fine for my Infinity stereo. It could be a couple things. 1) the sub is blown 2) the amp blew a fuse for the sub channel 3) the amp just crapped out on the sub channel. Maybe try quickly hooking up the stock head unit again and see if the sub plays. If not, you may be SOL.
Old Apr 22, 2007 | 08:32 PM
atombomb33's Avatar
EvoM Community Team
Sorry...forgot one more thing. Your head unit may have bad rear channel RCA outputs. That's probably not likely if you HU is new...but that could the cause.
Old Apr 23, 2007 | 02:43 PM
Spoonierme's Avatar
Sub works with the stock HU plugged in..
I just wanted to know if there was another connection i forgot or something i could have messed up on, but i guess not by you guys response.
I guess i'll just have to track the problem. thanks
Old Apr 27, 2007 | 12:18 PM
Guyver's Avatar
Spoon did you ever figure it out? Just curious..
Old Apr 28, 2007 | 01:57 PM
GPTourer's Avatar
Yeah, really - I have the same setup and my sub works just fine. But I had someone else do it for me.
Old Aug 11, 2007 | 06:06 AM
slicedbreadno2's Avatar
Where do you buy a mitah cable.
