Just installed Jensen VM9312 (low volume static)
Old Jun 13, 2007 | 08:10 PM
DSMEVOLUTION's Avatar
Ok just as the title says I just installed a Jensen VM9312 which in dash flip screen dvd player, etc...... Anyways the unit is absolutely flawless, I also just put in the ebrake bypass code to play DVD's while driving. Anyways my only complaint is that at very low volume where you cannot hear any music playing I can hear static, it's faint but it's still there. Whe I start up a dvd I can hear the radio through the low volume static. Once I turn up the volume all seems fine. What could be the cause of this???
I aksed my dad and he said that's usually a sign of a bad gorund, is this true? I could not find a proper ground for the unit so I left the wire off until I could find a good one. To my suprise once the unti was mounted screwed down it worked without the ground wire hooked up. Has anyon ever experienced a problem like this?
Any help would be greatly appreciated!
Old Jun 13, 2007 | 08:14 PM
SqEvoVIII's Avatar
probably grounding (badly) through the antenna. Just ground it to some metal.
Old Jun 13, 2007 | 08:17 PM
Tarmac_IX's Avatar
i have noticed that with myy factory unit... when i play cds i hear static and the radio i know has to be turned up loud for some reason
That seems odd but very likely.Where is the best place to ground, I couldn't find a damn place anywhere.
Old Jun 13, 2007 | 08:23 PM
SqEvoVIII's Avatar
You can ground it by sliding a ring terminal in between the plastic and metal screw hole where the factory radio screws in or drop a wire down to the cig ligter is the easiest. The best would be to a piece of metal in the dash without paint or with a star washer.
Old Jun 14, 2007 | 06:20 PM
Ok I just grounded it to the metal casing surrounding the radio. I had to take the glove box off to get to it but it basically clamped the wire down with a bolt. This casing is attached directly to the frame. I can tell the radio was grounded because didn't hear a pop when I plug in the antenna to the headunit.
Now the problem is that I can still hear the radio when I have the volume set to 1 with either a cd or a dvd in. It will play the station that it was last set at. I checked all my connectons over and everything is fine. I even wrapped some electrical tape around the rca connectors where you can see that metal showing just in case. The weird thing is that you can only hear the radio through the rear left speaker......strange
However messing with the there is something called RDS which basially searches for the name of the radio station when you tune through and it will show it to you. When I turn RDS to off I can no longer hear the radio everything is fine. It seems like this function does not know how to shutoff problem when changing inputs. Has anyone else experienced this problem??
Old Jun 15, 2007 | 09:17 AM
atombomb33's Avatar
EvoM Community Team
Sounds like a problem with the unit. Seems like you've got everything wired properly now.
Old Jun 20, 2007 | 07:29 AM
I got everything figured out now. I went onto the Audiovox website because the own Jensen and I submitted a ticket stating my problem. Within 3 hours I got a response back with a link to download the software upgrade and there was another link with instructions. I had to burn 5 files to a cd-rw and insert the disc into my unit and let it download. Funny thing is the is desrcibed my exact problem for the upgrade. not entirely muting the radio when you switched to a cd or dvd and it only played through the left rear speaker. After the software upgrade everything is perfect now!
Old Jun 20, 2007 | 08:04 AM
chaz517's Avatar
just bought this unit as well, good price too, 379. i am very anxious to get it and try it out. i read some awesome reviews about it, and it wiill make the interior a lil bit better. how hard was the install? what connection harness did you use if any? thanks
also how clear is the picture?
Old Jun 20, 2007 | 12:13 PM
Installs just like any other headunit, i've done a ton before so it only took me 15 minutes. I just bought the harness at best buy. I needed a special adapter though because I have an SSL sound system.
The unit is flawless and picture is good, it's not HD but it's good.
Old Jun 21, 2007 | 08:33 PM
felickz's Avatar
low volume static is probably from the fet's in the amplifier (possible that you may not be able to mute it)
Old Jun 25, 2007 | 05:31 AM
joey0480's Avatar
i have the unit to. I like it. No issue. did you run it on the stock speakers? I am looking to upgrade mine. Sounds a heck of a lot better than stock, but want something clearer.
Old Jun 27, 2007 | 12:14 AM
ImJoey's Avatar
I have this unit as well.My low volume static is more like a faint ring.I havnt heard my unit do it in the evo but it did it in the car it was installed in previously.That crap annoyed me.What is this cd-r you speak of?
Old Aug 26, 2007 | 08:40 AM
fyreant's Avatar
i just bought a phase linear (by jensen) model uv8.. basically same thing that you have.. my box says it comes with RDS but i cant figure out how to turn it on.. how did you turn yours on??
Old Feb 9, 2009 | 06:03 AM
RpR's Avatar
RpR
A bit off topic here, but does anyone have the link to the above mentioned firmware? I've mailed to Jensen some days ago and haven't received any answers
yellowevo82
Nov 8, 2010 12:33 AM
Boltz.
Dec 31, 2009 12:09 AM
Silhouette
18
Aug 23, 2009 02:47 PM
Xearo
Apr 20, 2009 05:54 PM
DSMEVOLUTION
17
Jan 7, 2008 08:23 AM
