M~'s audio install
Old Jun 19, 2007 | 03:09 PM
macster's Avatar
Arrow M~'s audio install
These are shots of my audio install. This was my first time at trying to build a box. I'm okay with the way things came out, but I'm going to hide the cap, but for now it stays. Also, I'm still waiting on my fiberglass box from Wickas.com so that I can finish up the install.
System details:
Amps: J/L 300/4, 500/1
Speakers Infinity 50002i, 652.5i, sub J/L10w3v2(for now, maybe, kinda sorta)
Interconnects: Fosgate for sub (shoulda bought all Fosgate. Stingers for front/rear channels.
Speaker wire: Stinger 16 gauge
Cap: Stinger 1.5 MF
PWR Distro block: Directed (good stuff IMHO)
Grd Distro block: Fostgate (damn I love their stuff)
Pwr wire: 4gauge
Amp wire: 8gauge (for now)
The start
Note where the powerwire goes into the fender. (blk straptied harness above the connector.)
The deck (which has 3 pre outs)
I love this stuff!
The routing (some of it)
Completed install on the deck
My first amp rack (I failed shop class 40 years ago)
12 disc CD changer (old folks need music too)
Sub Test box (screw buying em without listening to them in the car)
My amp rack again. She ain't purty, but it's all the same in the dark!
Done!
Another view
Final comments!
I'm real happy, with the box . That said, I had to do some cutting and trimming to get my sub to fit. (in the overall scheme of things, no biggie). Notes: I attached mine by drilling through the bottom of the sub with 3/4" flat head metal screws (got em from HDepot). I also drilled through the flat wall side facing the back of the sub woofer. Yeah I know. What I did was to open, the pull-out door in the panel behind the sub. I then inserted a piece of 1/2" MDF which filled that whole area (8"X6") and attached it to the frame (Metal part of car to your right behind the door panel) with 3 flat head 3/8" screws, 1" from top and bottom of the board (to prevent cracking) and spaced them evenly apart. I then pull on that sucker and it was tight. Now that took care of having a vertical attach point for the sub. It is now rock solid, and the only thing that I have to do is fill it with polyfill. I love the box, and the price was more than fair. I got a quote of $250.00 for the same box locally. But I wanted to go with something that, I knew that worked.
Whew! I'm too old for this. Now, I gotta save up for cams, fuel pump and a custom tune.
m~
Old Jun 19, 2007 | 03:29 PM
LayinLo's Avatar
Not too bad, Macster.
So which sub you going with? Is that a MTX 4500?
Old Jun 19, 2007 | 03:55 PM
atombomb33's Avatar
EvoM Community Team
Thanks for posting Macster. Always good to see install pics. So, at this point you're just waiting for the FG box from MconsliA4 and then you'll install your 10W7...right?
Old Jun 19, 2007 | 04:02 PM
LayinLo's Avatar
Yeah, I'm sorta a car audio nerd....
Can't wait to see the pics with a w7.
Old Jun 19, 2007 | 04:43 PM
macster's Avatar
Thank's, that's a 7500, but I'll probably go with the J/L. I'm going take a listen to one of the Rockfords and then that will be it.
m~
Old Jun 19, 2007 | 04:44 PM
macster's Avatar
Yeah, that will most likely do it.
m~
Old Jun 19, 2007 | 07:00 PM
DontRevMe's Avatar
im just checking, but you arent refering to the w3 pictured as a w7 are you? lol..
Old Jun 19, 2007 | 07:01 PM
DontRevMe's Avatar
oh i would also throw some PC fans in that amp rack Just in case.
Old Jun 20, 2007 | 06:03 AM
macster's Avatar
Yeah, you got me! I'll change it.
m~
Old Jun 20, 2007 | 06:09 AM
macster's Avatar
I was thinking about that. I designed the front of the box so that the area where the amp cooling fins are would be open. But I'm still leaning toward adding one or two PC fans, which I have plenty of.
m~
sharkm87's Avatar
so far so good
Old Jun 20, 2007 | 02:19 PM
alan678's Avatar
Looking good!
Old Jun 28, 2007 | 05:00 PM
MConsoliA4's Avatar
any updated pics?
Old Jun 29, 2007 | 06:25 AM
macster's Avatar
YUP! I'll post them later today.
m~
Old Jun 29, 2007 | 07:00 PM
MConsoliA4's Avatar
wish i knew you were gonna run a w3 in there i woulda routered that out before shipping it, reason i didnt was because it comes set up for a w7, well at least you were able to get it taken care of. Glad to hear your pleased with the box!
