help with electrcal problem!?
Old Sep 10, 2007 | 07:50 PM
black E's Avatar
I have an 04 with SSL . I got an pioneer headunit and i also got both cables (MITAH,power).
Well my problem is that when i turn the lights on, the lights on passenger side of the car (not the HID's) shut off as well as my interior lights (not the dash).
So i find a blown fuse in the engine bay that corresponds to the passenger ligths....so i replace the fuse and .....the fuse blows again!!!
Any help is greatly appreciated.
Old Sep 10, 2007 | 08:58 PM
YtDiamond05's Avatar
You have a dead short somewhere. Did you hook up the orange wire(Illumination) behind the radio? If so make sure its not touching ground, or simply cut it and tape it off.
Old Sep 10, 2007 | 10:10 PM
eclipsegsx012's Avatar
Yeah there is def. short somewhere. If this started to happen after you install the headunit i would look into those wires. Also as YtDiamond05 said tape of the wire that you see that is exposed.
Old Sep 18, 2007 | 07:42 AM
evo4g63awd's Avatar
cut and tape off both orange wires for radio (one is illumination/ one is dimmer)- that is if you have both. no one uses them anyway!!! they could be the opposite polarity causing this issue to happen. The reason why one side is only going out is because mitsu wires so that everything with the lights is independent from L to R.
