Viper Door Lock Relay for 791xv
how the hell do you install this thing? i thought i just had to plug the 3 pin harness into the control module and then connect the purple/black (w/ 15 amp fuse) wire to a 12v constant, the blue/black wire to the power unlock wire, and the green/black wire to the power lock wire. do i need to do anything with the brown/black and white/black wires? would the Door Lock Relay not work if i connected the door trigger input or factory disarm wires incorrectly?
you dont use the 2nd unlock wire and you hook the purple black wire to what ever the unlock/lock polarity is so if it is negative hook it to ground. you dont use the white/black wire or the brown/black wires there only for 5 wire door locks
