new system questions..
Old Dec 19, 2007 | 09:55 PM
diiirk@AwdMotorsports's Avatar
so i just installed an Alpine 10" Type-R sub with a Kenwood KAC-8103D Amp. ive got it all hooked up and everything, im just looking for some advice to get it configured for best sound. can anyone recommend some good settings for nice clean bass. im not into crazy bass, i just needed SOME bass.
Im looking for the following info:
what should these be set at
on the AMP
Bass boost level control knob (reads from 0-18db)
LPF freakquency (40-200hz)
ISF (off_15hz_25hz)
Input Sensitivity ( 5 - .2 V)
on the headunit
Sub.W phase 0degrees or 180degrees
Sub filter (80hz_100hz_120hz)
thanks guys, any help would be appreciated, i do not know much about systems whatsoever.
Old Dec 19, 2007 | 10:07 PM
YtDiamond05's Avatar
Its going to vary with the way you think sounds good. I would do bass boost off, low pass at 80 or so to start, isf off, input sens(gain) at lowest, and listen. Slowly bring the gain up to where it sounds good from the drivers seat. If you can turn the filter off on the radio do so, let the amp filter out the frequencies. If needed, you can bring the bass boost up.
Old Dec 19, 2007 | 10:30 PM
if i have the bast boost set on 0. there is no bass whatsoever. im only getting bass with it all the way up.
i had some issues with the install. The back of my jensen in dash dvd had rca cables for front and rear, but for the subwoofer it was a single blue rca cable. i used a y splitter to connect the rca's from the amp to the head unit. will this cause a problem.
also, when the volume reaches a certain point, the bass will stop. Even when the volume is not too high. if i get to about 70% volume it stops pumping bass.
Old Dec 20, 2007 | 10:03 AM
Is the amp turning off when you turn it up? Turn the volume up until the bass is gone, then check to make sure your amp is still on, and not clipping. The y adapter will not mess with anything.
Old Dec 20, 2007 | 10:14 AM
Also, what ohm is your sub?
Old Dec 20, 2007 | 11:34 AM
Audio Integrations's Avatar
Double check the ground on the amp as well. Do you have multiple devices connected to the jensen amp turn on?
Old Dec 20, 2007 | 12:51 PM
I will check to see if the power cuts off when the bass does.
The kenwood amp is the only thing that is wired to the jensen amp turn on.
The subwoofer had 2 options to wire it for 4 ohms or 8 ohms. it had these little wires that you wire over on the actual speaker for either the 4 or 8 ohm.
right now it is wired for 4 ohms
Old Dec 22, 2007 | 02:33 AM
sillyrpm's Avatar
just start messing with it and you easy figure how to work it...
D1no
17
Jun 10, 2009 05:27 PM
dbsears
Nov 11, 2008 01:51 PM
dbsears
Apr 2, 2008 05:57 PM
93civEJ1
Jan 30, 2008 11:32 PM
Illl
34
Jul 15, 2007 06:03 PM
