Effective Areas to dynamat an Evo?
#32
hmm, I may take that into consideration. Ive been really disappointed with their products, I had my entire car raammatted when I had the sti. We'll see though, I'm up for suggestions.
#38
#40
once the weather gets alil warmer(so no need for heatgun), im gonna by some damplifier pro... double-layer on the trunk floor to exhaust noise, single layer on the trunk firewall, trunk roof and inside fender. most likely not doing doors or floor as im dreading removing panels
#41
well i was just concerned about my trunk rattling from my subs. i dynamatted the trunk floor and the trunk lid. the only rattle i got was from my tail lights and license plate bracket so i put extra dynamat on those areas.
#42
#43
What did you want to know??
Honestly, I don't think your plan is going to negate much of the noise. Remember, sound move from bottom up and side to side. If you choose not to do the floors and/or sides then there really is no benefit to what you're doing.
The easiest panels to remove in the Evo are the door panels. I don't see why you wouldn't remove them and get some matting in there.
I posted everything in a post above for the OP on what your goals are and how to attack it.
Waiting until it is warm to not have to use a heat gun is okay but I would leave the matting out in the sun before you apply it. Also, buy yourself a hard roller. You'll thank me later...
#44
but you said do most of the trunk to reduce the exhaust drone..... isnt that what i said? double layer on trunk floor, single layer on trunk sidewall/firewall and trunk hatch? ill get a hard roller, thx
#45
Guys, I cannot say this enough times... I don't mean to sound like an *** but if you're going to do this one time, do it right...
If your goals are to have a car as quiet as a Cadillac then mat the WHOLE care from top to bottom side to side. It's a little un-realistic but you get my point.
Remember, sound travels up...
For example, the exhaust system is under the car... It finds itself between the road and a tin can... The road bounces the sound back UP and it hits the car. Now you have the exhaust noise traveling up through the car, hence why you put deadening on the floors. Most vehicles have their exhaust systems exiting the rear of the vehicle via the muffler and/or a tip. Where does this usually terminate? You guessed it, under the trunk. Hence why I suggest matting the trunk area to eliminate exhaust noise as well. You can actually get 3 benefits out of doing the trunk area, one eliminate exhaust noise, two eliminate road noise, three keeps your bass inside the car if you have a 50 Cent bumping sub system.
For sounds quality of a system, think about the speakers. Which way are the speakers sound waves moving? They're moving outward... Thus, the sound is going to travel through the doors most likely. If you've ever been in a car and listened to a sound system before and after a matting, you notice you can hear the radio better and don't have to blast the volume to at least hear it. This is why I recommend matting the door skins to force the speaker's sound to travel INTO the car.
Lastly, where is the ultimate place that all this sweet humming coming from? You guessed it, the engine bay. Hence why I recommend matting the feet areas as close to the firewall as possible.
It really is all common sense and I understand some things just take a little learning to grasp. Just think about WHAT you are trying to accomplish and/or eliminate and think about how it travels like I explained above. There really is no secret to deadening a car.
The ONLY offset of doing it is weight. If you're conscious about weight due to drag racing or road tracking. You may not want to do as much matting.
My car will only see a road track once a year IF that. I am not a hard core drag racer but will drag it maybe 1-2 times a year IF that. So the weight issue was not a big factor for me when I matted my car. Like a poster above said, this stuff can get up to 1lb/sq ft. Think about that for a minute... 1 12x12 sized tile that weighs 1lb in your car. Now put 60 of the tiles in your car in one spot...
Some things to think about.
