shorter antenna
Old Jan 28, 2008 | 09:31 PM
Jameson_IXMR's Avatar
Probably can. I got the washer in the section with cast-iron and steel fences. Its a black (to match the fence?) washer that is Stainless Steel. If you just go to hardware you wont find the colored ones most likely.
Old Jan 30, 2008 | 08:31 AM
kingman4's Avatar
If you put anti seize on the antenna threads, could that improve reception? I'm running the perrin stubby and it has noticeably less reception.
Old Jan 30, 2008 | 05:52 PM
ixmrgg's Avatar
good discussion here:
https://www.evolutionm.net/forums/sh...d.php?t=247251
I have the Agency Power one. Quality part, and the gunmetal one is fairly close match for GG-owners.
Old Jan 30, 2008 | 06:33 PM
EvoJedi77's Avatar
I just cut my stock antenna right after it turns thin. And theres some white stuff left, I just used a black sharpe and its covered now..
Looks good. And its
Free.
Old Jan 31, 2008 | 12:00 AM
YtDiamond05's Avatar
The perrin one sucks, reception is horrible.
Old Jan 31, 2008 | 09:49 PM
veilside prius's Avatar
Looks good. And its
Free.
thats what I did.
Old Feb 1, 2008 | 07:27 PM
EvoJedi77's Avatar
Just put the stocker back on, cut it, and then sell the Perrin.
Originally Posted by veilside prius
thats what I did.
I think we owned everybody
Old Feb 2, 2008 | 12:02 AM
anti seize wont inprove reception....it would hurt it. Just spray out the connector hole with isop. alcohol or electrical contact cleaner, wipe it out with a q-tip. Do the same to the new stud going in. Let them dry for about 45 minutes, mabye apply some type-2 cpc (light spray) and install it. Really just cleaning it with alcohol will make a big diff. If you still have bad recep, mabye its your head unit, or connector to head unit, or wiring to antenna? Or your antenna has an internally open wire.
Old Mar 18, 2008 | 06:23 PM
urslo4n8's Avatar
I have the 2" perrin and the receptions HORRIBLE. But its looks nicey-nice
Old Mar 18, 2008 | 08:04 PM
QwikEVO's Avatar
cut your stocker.
I noticed no change in signal.
Old Mar 18, 2008 | 08:51 PM
Kracka's Avatar
I have the Perrin shorty 2" on my IX and I am happy with it. The radio reception was barely effected.
Old Mar 18, 2008 | 09:45 PM
evolutionEvo's Avatar
i had the S2000 antenna and know i have a Perrin stubby
Old Mar 19, 2008 | 11:48 AM
EVOkitTeN's Avatar
Stock Antenna FTW... shorty antenna's look like the belong on the short bus
Old Mar 23, 2008 | 01:36 PM
In2Boost's Avatar
I bought one from Honda for the Element. Although it looks like the one for the S2000, the part numbers are different. Perfect fit and reception.
Old Mar 27, 2008 | 12:21 AM
Bizo2's Avatar
i bought the Freedom Design shorty antenna and have not noticed any reception problems yet
