No power to my amp...Help
Old Apr 8, 2008 | 01:38 PM
boostedawd's Avatar
I've run the power wire, and ground to my amp (RF 600w). The fuse is good, and the ground is good. As far as i know, its getting power and a good ground. But for some reason, its not powering up.
Do amps have internal fuses? Could i have blown that? Its probably something stupid, but i can't seem to get any power to my amp.
Old Apr 8, 2008 | 01:43 PM
igo4bmx's Avatar
do you have a remote turn on wired up?
Old Apr 8, 2008 | 01:51 PM
boostedawd's Avatar
Whats a "remote turn on" ?
I bought the car with a system already installed. It was done professionally, but before i bought it, the previous owner took all amps and subs, but left speakers and wires intact.
Old Apr 8, 2008 | 02:27 PM
CanMan's Avatar
Should be a blue wire from your head unit that goes to your amp. It should be marked "remote" or something similar on the amp. That is the wire that sends the signal from your head unit to your amp, telling it to turn on. Also, if that is already hooked up, check the fuses on the amp.
Old Apr 8, 2008 | 05:36 PM
boostedawd's Avatar
opend the amp up and there are no fuses in there at all.
I checked with a multimeter and its def. getting power. and there is nothing wrong with the amp. its just not turning on ....
Old Apr 8, 2008 | 06:20 PM
Lunchb0x's Avatar
remote wire is somethin that sends a negitive signal to the amplifier from the radio letting it know to turn on...remotely... there should be a blue wire, or blue with a stripe dont remember but u need to run that wire from the radio to the amp where it says....REMOTE WIRE usually between + and -
Old Apr 8, 2008 | 07:10 PM
SCEvol8's Avatar
Yes, as others have said, do you have a remote wire hooked up? The remote wire is what triggers your amp to turn on based on your turning on the head unit. This is often a blue wire.
Old Apr 8, 2008 | 07:25 PM
boostedawd's Avatar
Yes, i have the remote wire hooked up.
Old Apr 8, 2008 | 07:51 PM
LayinLo's Avatar
Edit, just saw your other thread and replied in it first.
Old Apr 8, 2008 | 09:27 PM
biggie5252's Avatar
try taking a piece of wire and wire it from the power wire terminal on the amp to the remote turn on and see if it turns on then. Maybe your amp is toast.
