Direct gauge replacement for MRs?
Old May 17, 2008 | 09:22 AM
MRedition05's Avatar
I went ahead and deleted my OP because I answered these questions myself. Apparently the stock MR gauge cluster on the bottom is what is being sold on various sites as the "radio relocation kit". I went ahead and moved my gauges up into the radio spot and changed them so the boost gauge was the closest one to me with just a screwdriver. I'm just going to order an aftermarket mechanical boost gauge and drop it right in.
Old May 20, 2008 | 09:51 PM
ball7068's Avatar
bump
Old May 21, 2008 | 05:11 PM
Deleted
Old May 30, 2008 | 07:51 PM
Bounty Hunter's Avatar
BUMP...surely someone has done this.
Old Jun 4, 2008 | 04:23 PM
selp's Avatar
you will be able to use the vacuum line, but you will need to rewire the illumination wire, ground and power. (if available)
Old Jun 7, 2008 | 11:53 AM
EvoKnievo's Avatar
where did you find a 42mm mechanical boost gauge?
Old Jun 18, 2008 | 05:56 PM
I didn't have much luck with it, so I just put an Autometer pod on my column with a 2" 1/16th gauge in it. I really don't like having a dead gauge in my dash though, so I'm trying to figure out what to do with it. I might put my boost controller in there or upgrade to the Autometer 3 gauge dash pod and put an AEM wideband in there. I dunno yet. I found a few 1" 1/2 gauges that will fit in the stock pod but they seemed little too cheap for me. The one good thing was that on the MR you already have a 3/8 boost line run up to the dash, so I just put a tee in there, ran one line to my new gauge and the other to my boost controller so it saved me a step. But if you REALLY want a boost gauge that fits in the stock location, then here you go http://www.marshallinstruments.com/products/W.cfm
it comes in a 0-30 psi
Old Jun 18, 2008 | 06:20 PM
I-Dom-In-8's Avatar
If you want a boost gauge that fits then you need This one....the stocker is 42mm..you have to dremel out the stock hole just a little bit..
