Where to mount this?
Old Aug 25, 2008 | 03:48 PM
biggie5252's Avatar
+1 on the fuse setup other than you apparently already have a breaker. You should measure resistance across the contacts with a multimeter.
Old Aug 25, 2008 | 05:53 PM
TonyMS's Avatar
I have read so many different opinions between fuses and circuit breakers in the end it is all hooked up sounds and looks great. I measured a fused setup that I had it measured at .4 ohm the circuit breaker measured the same so they seem to have the same resistance.
Old Aug 25, 2008 | 07:27 PM
biggie5252's Avatar
You should try touching the leads of your meter together and see what they are alone. .4 ohms seems pretty high. 10 amps across that will drop 4 volts. I'm not trying to push the issue, just trying to help you out.
Old Sep 17, 2008 | 01:15 AM
ixmrgg's Avatar
Originally Posted by TonyMS
Good idea with the velcro....I guess I will try it out I can't seem to come up with why it would be bad and I can't find anywhere else suitable to mount this thing.
in case regular velcro isn't suitable (the fabric may hold moisture and thus mildew), maybe take a look at 3M "dual lock":
http://www.itapestore.com/index.asp?...n=Custom&ID=19
Old Sep 28, 2008 | 11:55 AM
MRTASK's Avatar
I Ziped Tied Mine To The Some Wires On Back Of The Bat & It Been Good To Me
Old Sep 28, 2008 | 03:03 PM
TonyMS's Avatar
I used velcro and it has been fine I used the plastic to plastic really heavy duty stuff. So one month no issue and that was with a drive up to Pigeon Forge area.
Old Sep 28, 2008 | 03:11 PM
Sharkbite2000's Avatar
I relocated mine to the rear in the trunk a pain in butt but it's worth it.
Old Oct 13, 2008 | 04:42 PM
scanevo's Avatar
get a thin piece of steel or aluminum and make a bracket, you want a secure hold on that breaker.
