Stupid, Stupid, Stupid
Old Aug 18, 2008 | 03:27 PM
BoostLover99's Avatar
Exclamation Stupid, Stupid, Stupid
Not like anyone really needs to remind you but . . . MAKE SURE your negative battery terminal is disconnected before you do *anything* electrical.
Being the brilliant genius that I am, I figured it would be easier to put in a new head unit without doing this (how am I gonna test the new head unit before screwing it in if the batt's disconnected, right?).
I shorted out something really important and now have lost the following:
1) Clock
2) Trip odometer
3) Power doors or windows (without ignition)
4) Keyless entry
5) Dome lights
Yeah, I checked all the fuses and only the dome light was blown. Boy am I glad I saved $50 by doing the install myself . . .
Time to visit the dealer and bring the checkbook. D'oh!
Oh, I forgot to mention that because keyless entry didn't work, I locked myself out at Lowe's and had to spend $45 for a mobile locksmith to come and break into my car. Boy, I'm really good at saving that money, aren't I?
Old Aug 18, 2008 | 03:32 PM
Curt@MrLed's Avatar
Former Vendor
You still have a blown fuse. Check both fuse boxes. Things happen, dont complain, just find it and fix it yourself. Youll save money and learn a few more things.
Old Aug 18, 2008 | 04:38 PM
biggie5252's Avatar
^^^+1 It should be one of the fuses in the little yellow clip (with 2 fuses in it) under the hood (that's the usual fuse that blows). Don't worry, this happens all the time. There's usually a thread about this same thing every couple few weeks.
Old Aug 18, 2008 | 04:48 PM
ASIXMRSE's Avatar
lol live and learn.... coulda been worse honestly... and thats what fuses are for.
i had a buddy try to re mount the license plate on his gixxer lower, and right where the rear coilover is.... so he drills two holes in the panel right there... turned out he drilled straight through a 900 dollar ecu. ouch!
good luck bro.
Old Aug 18, 2008 | 06:01 PM
I checked EVERY single fuse in both the engine compartment and the passenger compartment. The only blown fuse was the the one for the dome light.
Yes, I checked the fuses inside the little yellow clip (which was a massive ***** to get out of the box), also.
Old Aug 18, 2008 | 06:05 PM
4g63smokinall4s's Avatar
Hes right this same thing happened to me and thats where the blown fuse was..
Old Aug 18, 2008 | 09:42 PM
biggie5252's Avatar
Check those fuses with a multimeter on the ohm setting. If you get anything but 0 or very close to it they're bad. Sometimes, although pretty rare, you can blow a fuse and it not be easily visible. That or you need to recheck your wiring.
Old Aug 18, 2008 | 09:49 PM
Jasil's Avatar
Fuse.
Old Aug 18, 2008 | 11:17 PM
Will do - thank you!
Old Aug 18, 2008 | 11:18 PM
good luck bro.
Morbidly, that actually helps me feel better - thanks, man!
Old Aug 18, 2008 | 11:19 PM
It's interesting that my post occurred to you as complaining - I'm sorry that's how it occurs for you.
I'll keep checking those fuses.
Old Aug 19, 2008 | 12:09 AM
The Little Dome Light 10A Fuse Is The Key
It turns out that *EVERYTHING* (well, I haven't checked the trip odometer yet) that was broken for me hinged on that little dome light fuse; I was checking and checking and checking (even with an ohmmeter as suggested) each of the fuses looking for the "other ones" that were blown to restore functionality to my power locks/windows, keyless entry, etc.
Well, all of that stuff is run off of the dome light fuse, apparently!
This is going to be a significantly cheaper visit to the dealer than I expected!
Thanks, everyone!
BoostLover99
Old Nov 28, 2010 | 08:13 PM
hyp36rmax's Avatar
I'm having this same issue, the dome light fuse keeps blowing... >
Old Nov 28, 2010 | 08:50 PM
buchnerj's Avatar
IF a fuse keeps blowing that means there is a short somewhere. What did you change? Go back and look at the wiring, somewhere there is a lead grounding out, either wire on wire, water, etc.
Double check everything.
Old Dec 3, 2010 | 05:53 AM
Short_Block's Avatar
I would have fired myself too.
You will get it squared away.
Did you check the underhood fuses?
Ben
