SSL Aftermarket Radio install
Is it possible to wire up an SSL with an aftermarket radio without using the converters? Could you go from the radio to the amp with out it, or is there a signal conversion going on? Also, is the sub run off the amp, or is it self powered.
Thanks
Thanks
I assume your talking about the adapters. There are many places that sell them and can be found with a simple google search. I bought my deck from crutchfield so they came for free with my deck. If you already have a deck however im sure you can just purchase the adapters separately.
just another quick question...
i did got the Mitah adapter.. but I can't control the SSL subwoofer as before, there is no way to adjust the subwoofer sounds since there is no wire for me to plug in in the back.. ?
and there my friend is the rub....
while the head unit works perfectly you will not have the fine tune control that you need to add that something special (bass) to the mix.
I have been tossing this around for along time. I think that I (and probably you) will eventually upgrade each piece until poof we take an 's' out of ssl.
I had to splice my subwoofer wire into one of the cables and that allowed me to control the subwoofer sounds. I honestly can't remember which one it was.
strife
85
May 12, 2025 04:08 PM
lznk41
For Sale - Part Outs
Sep 2, 2016 12:06 AM
henry22
Jul 1, 2014 09:23 PM
MharAndal
Sep 8, 2013 09:01 AM
turboedv6
10
Jan 1, 2012 11:43 AM
