Major problem
Old Dec 7, 2008 | 03:22 PM
Mr. PSSsSt's Avatar
FCOTM Winner
Major problem
okay guys so i was installing my defi guages and when i turned on my car the gauge would be on but it wouldn't light up. Then i noticed other things that didn't light up such as my climate control, cig lighter, one of the rear tail light and passenger light but the light on top of the corner. Also, everything works fine when my alarm is armed. I checked the fuses and everything seems fine. Any help will be greatly appreciated. thanx
Old Dec 7, 2008 | 03:28 PM
TTP Engineering's Avatar
Underhood fuse in fuse box.
Old Dec 7, 2008 | 03:32 PM
Mr. PSSsSt's Avatar
FCOTM Winner
what about it??^^
Old Dec 7, 2008 | 03:34 PM
Import Junky's Avatar
faulty gauge??? sounds odd that it's only partially working.
Old Dec 7, 2008 | 03:38 PM
Mr. PSSsSt's Avatar
FCOTM Winner
^the gauges work perfect only when my car alarm is armed.
Old Dec 7, 2008 | 03:42 PM
90GSX-03EVO's Avatar
Originally Posted by Mr. PSSsSt
what about it??^^
It's probably blown. That's why only one of your tail lights is out.
Old Dec 7, 2008 | 03:46 PM
Mr. PSSsSt's Avatar
FCOTM Winner
how about the climate control and cig?
Old Dec 7, 2008 | 03:56 PM
STItoEVOX's Avatar
Check your fuses. It's not uncommon that all these things would run off of one fuse.
Old Dec 7, 2008 | 04:00 PM
Curt@MrLed's Avatar
Former Vendor
Have you rechecked your wiring. Try disconnecting the wires and then see if everything is fine again.
Old Dec 7, 2008 | 04:03 PM
Mr. PSSsSt's Avatar
FCOTM Winner
disconnected everything but still having the problem
Old Dec 8, 2008 | 11:48 AM
Did you check the underhood fuses or did you just check the cabin fuses? I bet I know what will happen if you swap # 20 and 21 under the hood.....
Old Dec 8, 2008 | 01:56 PM
Mr. PSSsSt's Avatar
FCOTM Winner
check all the fuse in the cabin...what will happen if i change number 20 and 21?
Old Dec 8, 2008 | 01:58 PM
shupadupa's Avatar
he is betting it will fix your problem. Check under hood fuses.
Old Dec 8, 2008 | 02:12 PM
Mr. PSSsSt's Avatar
FCOTM Winner
i will tomorrow morning ...thanks alot for all the help guys hopefully i can fix the problem
Old Dec 8, 2008 | 02:23 PM
randomevo's Avatar
are 20-21 the ones in the yellow holder under the hood?
cause i just changed one of them today,the top one, and it was for the radio/clock/ door locks. wasn't fun to change either.
