alarm after turbo timer
Old Dec 10, 2008 | 11:10 PM
MitsuEvo05's Avatar
does anyone here have their alarm go off while or after the countdown of the turbo timer??
Old Dec 10, 2008 | 11:14 PM
sikrsix's Avatar
Why start another thread on virtually the same subject?
https://www.evolutionm.net/forums/sh...t=#post6452302
Old Dec 10, 2008 | 11:19 PM
MitsuEvo05's Avatar
only because nobody was answering...
Old Dec 10, 2008 | 11:39 PM
sikrsix's Avatar
Well nobody will answer this one either. The sad part is, you should be able to answer your own question.
Old Dec 11, 2008 | 12:40 PM
ernald711's Avatar
yea it doesn't look like you did any research. lazy people just post the same threads over and over again. well, lazy people and n0obs.
Old Dec 11, 2008 | 02:02 PM
gzzza8181's Avatar
I have never heard of that although any time i install a remstart alarm on a vehicle with a turbo it has a turbo timer mode wich keeps the alarm disarmed until shutdown.
Old Dec 11, 2008 | 03:42 PM
Mr. PSSsSt's Avatar
FCOTM Winner
my alarm is armed while turbo timer is running
Old Dec 11, 2008 | 06:55 PM
HELOVESTEHBOOST's Avatar
Just arm it while you're driving and you should be good to go. Your timer should kick in when you step on the gas, then brake, then gas, gas, in that order only. This is only if you have ever used VTEC. If you've never used VTEC the code won't work. Hope this helps.
