Orbital Kit and Avic-D3
Old Feb 5, 2009 | 11:14 AM
nashmage's Avatar
-Just got in my Oribital Upper Trim to go around the double din i was originally making my own but havent had time with work so i jut bought it...what im seeing now though is that It doesnt seem to fit at all....
-Its Tight up top has gaps on the left and right along with a huge gap at the bottom....
-The way that i have the D3 held in currently is that i took off the 2 brackets from my original infinity cd player and attached them to the d3
-it seems like the orbital kit wants the headunit at the bottom of the hole not the top...
I remember seeing a post awhile ago about someone who had a d3 and it didnt look like he did any modifications to his to make it work so thats why i thought i would post. Ill try to get a picture too once i get out of work if that helps. Im just assuming that im not allowed to use to stock hardware but wanted to check up with you guys for advice before i started modifying anything.
Old Feb 5, 2009 | 11:27 AM
Jrod@Buschur's Avatar
I just did an install here yesterday on our project Evo 8 with a Orbital kit and an Eclipse headunit.
I had to change the angle of the mounting brackets on the deck for it to fit into the correct position. Otherwise it was too high to fit into the face plate or had a gap. On the Eclipse unit there was about 8 different mounting holes which allowed me to change the position of the factory brackets that I had to bolt on. Im not familiar with the D3 so I can not comment on that.
With the brackets aligned correctly the Orbital face plate slipped over the unit perfectly. There has to be some room so its not rubbing.
Old Feb 5, 2009 | 12:20 PM
nashmage's Avatar
Thanks alot man im going to try and look at the headunit and see if their are any other holes that i could screw the brackets into because it looks like the kit wants the headunit to be held at a slant not facing straight as the old one was. IDK im going to have to look at it some more when i get out of work.
Old Feb 5, 2009 | 12:25 PM
Yes that is the case as I found out yesterday. The headunit has to be slanted for it to go into the Orbital piece.
Some decks will have numerous threaded holes on the sides for situations like this. Some do but do not have enough such as possibly only having 2 standard holes on each side. Hopefully you're covered.
Old Feb 5, 2009 | 01:10 PM
nashmage's Avatar
Im a at work most of today so i wont be able to look today but im sure it has the holes for it seeing as how ive seen a few people on this forum have it before. Hopefully when i get a chance to look it will be an easy fix.
Old Feb 5, 2009 | 05:20 PM
roevo's Avatar
i have the same kit with the D3 as well, and sits the same way, kinda sucks and i have tried different way to mount it ut still doesnt fit all that well
Old Feb 5, 2009 | 05:22 PM
injentech42's Avatar
i wanna do this to my car so bad
Old Mar 26, 2009 | 09:59 PM
Raceghost's Avatar
Not to hijack, but where can I find that HVAC reloc kit. I know it is discontinued, but there has to a be a few lying around somewhere...?
Thanks in advance. Nice setups by the way.
Old Apr 5, 2009 | 06:42 PM
genma's Avatar
Good Question.. New installs with Orbital Kits??? Where are they getting them?
