Upgrading Battery Terminals
Old Apr 5, 2009 | 11:01 AM
D1no's Avatar
I am looking to upgrade my battery terminals. The "+" needs to accept one 0 guage, two 4 gauge and the stock wiring block thing. The "-" needs to accept one 0 gauge, two 4 gauge.
Right now I have terminal rings at the end of the wires connected to the stock battery terminals mounting bolt. The 0 gauge wire is from the big 3 upgrade. One 4 gauge "+" and looking to add another 4 gauge "+", one for each amp.
The terminal rings seem to be too big and not making a full surface connection to the stock battery terminal.
There are alot of upgrade terminals available. I want to find out how people here in the forum deal with that fuse block comming off of the "+" stock wiring. Does the upgraded terminal need to accept this stock "+" wire terminal block? Which upgrade terminals did you use?
Thanks.
Old Apr 5, 2009 | 11:08 AM
edardnaekim's Avatar
google tsunami battery terminals. idk if there is anything out there for the fuse block though...
Old Apr 5, 2009 | 11:33 AM
D1no's Avatar
Thanks Bro. I need to find out how the people on here delt with the "+" wires and the stock fuse block. Then I can choose the right terminal with the correct size, type and number of outputs.
Old Jun 16, 2009 | 11:08 AM
itzwolf's Avatar
Did you ever find a solution for the positive side terminal and factory positive wiring? I am looking for a clean option as I am rewiring for an Iraggi 180amp alternator using 1/0g wire...
Old Jun 18, 2009 | 12:23 PM
D1no's Avatar
I ended up removing the stock batt. terminal and soldering a 4 ga. wire with spade terminal, to the positive cable. I left the diode piece intact. I cut up the red positive terminal cover, into a box shape. Covered the two soldered connections with this box and just wrapped it all up with good quality electrical tape. I then tucked it and zip tied it under the battery tray. 4 ga. from there to Stinger cable terminals. I did not like doing it like this, but it worked out great.
Four power wires, three 4 ga. and one 0ga. to the terminal just doesnt look good to me.
I think a distro. block somewhere, with just a single 0ga. to the bat. terminals would look cleaner.
RalliartN
19
May 3, 2023 03:31 PM
lancer02Josh
Lancer Troubleshooting
Aug 29, 2017 06:50 PM
mrfred
May 23, 2015 01:28 PM
Bigdon
May 8, 2010 01:25 PM
EvoIXMR
Jul 30, 2006 07:53 PM
