Evo 9: How to keep big battery with HKS IC piping kit
Old Feb 27, 2010 | 05:36 PM
Bigdon's Avatar
I’m in New Zealand so things are a little reversed compared to your USDM models.
This is really easy.
I have a big Orbital battery in my EVO 9 GT and wanted to keep it when I installed the HKS IC piping kit. It was a tight fit even with the factory pipe.
I firstly made a template of the bottom, top and side of the battery and worked out where it needed to sit.
I then removed the strut brace to make room to work
I then removed the factory battery tray, lined up the template and notched the sides of the tray.
I then drilled holes in the bottom of the tray and made up a new battery clamp to fit using large washers under the tray to support the clamp mounts.
I then extended the earths and used the after battery market terminals.
At the moment I’m using a bus bar off the second + terminal of the battery to attach the factory positive lead with the factor fusing. I do intend changing this and using some form of after market fuse block which then connects directly to the main + terminal to tidy it up.
The rubber shroud on the strut bar is good becuase it protects the + terminal
You will need:
Socket set
Solder
Soldering iron
Assorted ring terminals
Large washers
Hacksaw
Drill
Conductive material to make bus bar and material for batter strap
Potentially new battery hooks/rods
Assorted bolts and nuts
Power cable
Aftermarket battery terminals
Wire cutters and pliers
1-2hrs max
URL=http://img687.imageshack.us/i/img4158z.jpg/][/URL]
Old Mar 2, 2010 | 05:53 AM
jdm93cx's Avatar
that is a tight fit..
i moved mine to the trunk
Old Mar 18, 2010 | 03:50 PM
Bigdon's Avatar
It is tight, but not as tight as you would think, the orbitals are big batteries though.
I thought about the boot (have done it in other cars) but I have a custom install for my subs mounted in a false floor (and amp on the back of the seats) in the boot. So the battery would have made it look untidy plus limited what I could get in the boot like my golf clubs and rifles.
Also means you don't have the added weight of the cable and mounting hardware.
Old Mar 19, 2010 | 02:32 AM
Mark14's Avatar
Good info, have to look into that with the ams piping.
Old Mar 19, 2010 | 09:05 PM
From 3 to E's Avatar
good idea for those who are on the fence of getting a mini battery
Old Mar 23, 2010 | 02:23 PM
jdm93cx's Avatar
I had the same problem i had to move it into the trunk
Old May 8, 2010 | 01:25 PM
djikonatx's Avatar
good one man you beat me to it
Psquared
For Sale - Part Outs
Oct 3, 2010 10:12 AM
tc17
Jan 20, 2010 08:39 AM
evoxkrazy
Dec 22, 2009 12:49 AM
kmcconn9
23
Oct 24, 2009 05:11 PM
matt55
Jun 21, 2009 09:48 AM
