wiring
Old Apr 21, 2009 | 06:30 AM
N3VO's Avatar
wiring
dont know if this is the right place for this so if not mods please move
anyone know a 12v source under the drivers side or what color wire a 12v is?
Old Apr 21, 2009 | 07:47 AM
N3VO's Avatar
come on someones gotta know
Old Apr 21, 2009 | 07:54 AM
IXmr321's Avatar
what are you trying to run? not all things in the car have constant 12V power. But if thats what your looking for, splice into the head unit power.
Old Apr 21, 2009 | 07:56 AM
N3VO's Avatar
im trying to wire my uego wideband i have it tapped into where my boost gauge is wired right now which is tapped into a green wire which i htink is the headlights cause it only turns on when i turn them on so im looking for somethign that will turn it on when the car is on
Old Apr 21, 2009 | 07:59 AM
IXmr321's Avatar
Splice into the radio wire.
Old Apr 21, 2009 | 08:04 AM
N3VO's Avatar
i took apart the radio last night and pulled the harness but what wire do i tap into? theres quite a few
Old Apr 21, 2009 | 08:09 AM
IXmr321's Avatar
Go to the fuse block, find the radio fuse and follow the wire out of the fuse.
Old Apr 21, 2009 | 08:11 AM
nymike0731's Avatar
whats the status
Old Apr 21, 2009 | 08:17 AM
N3VO's Avatar
alright ill take a look, thanks
Old Apr 21, 2009 | 08:24 AM
N3VO's Avatar
i look at the fuse block but its all harnesses too plugged in, it seems impossible just to follow one wire
Old Apr 21, 2009 | 08:31 AM
Smike's Avatar
Moved to this forum. Guys here have more experience with wiring and whatnots.
Old Apr 21, 2009 | 09:14 AM
MRCole's Avatar
EDIT: Directechs says radio 12v red/black and ignition blue/yellow. I must have punched in the wrong car. The color is blue with a yellow stripe. That's what color/color means.
Old Apr 21, 2009 | 09:17 AM
N3VO's Avatar
sweet ill go check it out but when you say white/black does that mean the wire is white and black or its either a white or black wire?
Old Apr 21, 2009 | 09:18 AM
randomevo's Avatar
according to the manual, the red black wire goes to the battery
the blue/yellow wire goes to the ignition switch.
can anyone confirm this? OR did i miss something?
Old Apr 21, 2009 | 09:25 AM
MRCole's Avatar
You are right, I punched in the car in directwire and it said different colors this time. HAHA
