wiring
Old Apr 21, 2009 | 09:27 AM
N3VO's Avatar
so then which one should I tap into?
Old Apr 21, 2009 | 09:28 AM
MRCole's Avatar
Doesn't the wideband need both constant and accessory?
Old Apr 21, 2009 | 09:32 AM
MRCole's Avatar
If it doesn't need both, I would tap into accessory
Old Apr 21, 2009 | 09:34 AM
N3VO's Avatar
thats the diagram in the instructions i believe it just needs a 12v
Old Apr 21, 2009 | 09:56 AM
randomevo's Avatar
acc power i believe. Taped into a constant before and my gauge never turned off ;-)
Now i gotta recheck myself, but I'd say acc power.
Old Apr 21, 2009 | 10:05 AM
N3VO's Avatar
what color wire is that? blue with yellow stripe?
Old Apr 21, 2009 | 10:57 AM
biggie5252's Avatar
Yes tap into the acc wire. Run a separate ground to the frame of the dash. Don't splice the ground wire into another ground wire.
Old Apr 21, 2009 | 11:33 AM
N3VO's Avatar
i tapped into the blue with yellow stripe wire going into my radio and i did the grounding before and everything and it turns on when acc/car is on thanks guys!
Old Apr 21, 2009 | 03:44 PM
MRCole's Avatar
great n3vo glad you got it working!
Old Apr 21, 2009 | 04:20 PM
N3VO's Avatar
thank you for your help i appreciate it much and it saved me from splicing into more random wires btw is this wire i tapped into its blue/yellow an accessory wire? btw is this blue/yellow wire i tapped into an accessory?
Old May 5, 2009 | 10:23 AM
cbuster77's Avatar
splice into any power wire or the fuse box in the cabin
Inprogress
Jul 29, 2008 04:14 PM
Deepseadiver
Oct 22, 2006 07:40 AM
red evo8
Feb 1, 2006 11:26 AM
Derek888
14
Aug 10, 2005 11:30 AM
kiran197
Nov 12, 2003 07:42 AM
