Subwoofer popping
Old May 12, 2009 | 04:31 PM
Yimke's Avatar
Ground loop is happening. Here is some reading
http://www.crutchfield.com/S-wOkStfl...ech/kb350.html
or probably bad RCA's. Test them by swapping a new set across the seats to the amp for test purposes. If that solves it there is your problem.
if not try this procedure chart, because that hum is noise in the system. Follow chart till noise from subs goes away.
http://www.crutchfield.com/Learn/lea..._diagnose.html
Old May 25, 2009 | 11:24 PM
heel2toe's Avatar
Im not sure if this is the same thing but when I installed a full system in my friends car including a headunit speakers and an amp when we turned on the headunit, the speakers would pop. After speaking with crutchfield tech support(they are awesome btw) we were recommended a solution. Apparently the amp was turning on before the headunit and causing a pop. We were instructed to wire in line both a small resistor and capacitor. These were soldiered in line to the switched 12v going to the amp. Now I forget the specifics on the capacitor and resistor however what I can tell you is that it fixed our problem. I suggest getting in contact with someone from crutchfield tech support and see what they can do for you. Good luck and keep us posted.
Old May 25, 2009 | 11:56 PM
rocklee05's Avatar
make sure you amp turn on wire is connected to the blue/white wire from the pioneer harness, and/or turn down the frequency on the amp.
Old May 26, 2009 | 10:59 AM
QwikEVO's Avatar
swapped RCA jacks on the back of the head unit. problem gone.
guess that set on the back I was using is FUBARED.
stiffdogg06
19
May 28, 2015 08:33 AM
Dropspeed
12
Jul 27, 2008 06:50 AM
Racer24x
Apr 21, 2007 10:19 PM
EvoIXMR
Jul 30, 2006 07:53 PM
silverevo05
Mar 1, 2005 12:10 AM
