Twin Walbro install(Question)
Old May 28, 2009 | 08:06 AM
Ricekiller81's Avatar
I recently Purchased a Full Blown Twin Pump assembly and I became a little confused on were to source my Constant 12V source for the 2nd Pump. For the 1st pump I just ran the (+) (-) Source of the existing wires of the OEM Fuel pump harness. I already have the 2nd Pump Relayed to the StandAlone's negative Trigger switch. I searched and found the Twin Pump Install thread, but it was unclear on were to source the power for the 2nd pump.
So can I:
1) Use the same 12V source of the Fuel Pump Harness, but Ground the 2nd pump off a different ground source?
2) Just Run a wire from tank to the front of the car to the Fuse box directly to the 12V source?
Thanks in advance
-Jon
Old May 28, 2009 | 01:10 PM
Thanks for the reply's anyone else?
Old May 28, 2009 | 01:17 PM
evoDON's Avatar
i am wondering the same thing. i might have to do a twin walboro set up. anyone know?? thanks
Old Jun 1, 2009 | 06:20 AM
Can anyone one post up what they know please.
Old Jun 1, 2009 | 06:35 AM
9sectalon's Avatar
Run a 10g wire directly so there is no voltage drop. What is the Sellers recommendation?
Old Jun 1, 2009 | 06:58 AM
Im unable to get a hold of them because of my Work hours. Thanks for the advice man
Old Jun 1, 2009 | 09:07 AM
jid2's Avatar
You need to run a new 12 V line with high current wire (I used 10 awg). DO NOT use the factory harness for both pumps. I tried it and it creates a massive voltage drop and neither pumps gets proper voltage.
I ran a fused line from the battery to my relay which is mounted in the trunk, then to the pump.
Old Jun 2, 2009 | 06:03 AM
9sectalon's Avatar
Let us know how that works out. I need to go dual on mine also.
Thanks
Old Jun 2, 2009 | 06:36 AM
Awsome thanks man that what I need to know. I see all of us runnung 2.3L Nice
