So I ripped the rear o2 housing house... what wires go to what wires?
Long story short, I took the 02 out of my exhaust, unbolted the rest of the exhaust and dragged it out from under the car and the downpipe support bracket decided to take the o2 with it and pulled it out from the plug. There was a blue, white and someother color wire that are attached to the o2. When I looked at the other end of the plug, in the car, there was a black wire going no where, a blue, a white and a red wire with stripes. Naturally I decided to attach the blues and whites together and the mystery wires together. Well I through a CEL. So I was wondering what wires were supposed to go where? Thanks.
Simply disable your rear o2 sensor with the Tephra/mrfred mods and you can just remove it and never worry about throwing a code again. Check out the ECUFlash section if you don't know what I'm talking about.
happened to me before trying to extend wires I got em confused..
there are 4 wires..
2 are because of the sensor being a heated sensor
..so if you throw a code- switch the only two that are the same color and you should be good
there are 4 wires..
