Fast Blinker!!
Old Jun 30, 2009 | 12:36 PM
mitsurage's Avatar
Fast Blinker!!
I need Help With My turn signal its blinking really fast. its starts off slow then it goes fast!.. the 194 bulb i made my blinker and the inner bulb that supposed to be the blinker is now the the light thats constant when i turn the corner lights on.. please help just want to know if i got to change out the relay to a aftermarket one.
Old Jun 30, 2009 | 01:47 PM
4G63K's Avatar
Check your rear or front light while the blinker is on. One of them is burnt out. Ususally when the blinker starts to blink fast one of the bulbs is burnt out.
Old Jun 30, 2009 | 02:05 PM
InjectedPerf's Avatar
+1 a real fast blinker usually means 1 of the bulbs is burnt out
Old Jun 30, 2009 | 02:08 PM
MaD_CaNaBiCe's Avatar
Do what he said^^^(For example if you front left turn signal bulb is not working then the rear left signal light will blink fast) check for a bad connection that can also be the problem
Old Jun 30, 2009 | 02:48 PM
mitsurage's Avatar
all the blinkers work i've checked them all.. cuz im thinking when i switched the bulbs around isntead of the 194 bulb being the corner light its the blinker it self now. yeah should of stated that first..lol.. all lights work.
Old Jul 1, 2009 | 06:13 PM
wynn456's Avatar
it works on voltage the difference is what makes it blink fast you need to put a resistor in to stop that
Old Jul 1, 2009 | 06:23 PM
Turbodemon's Avatar
Some bulbs have 2 seperate filaments depending on the type of blinker and some have one make sure you didnt put a 2 filament bulb where a 1 filament bulb is supposed to be or vice versa
Old Jul 1, 2009 | 06:27 PM
eve-slow's Avatar
Ya dual fillament.
Old Jul 1, 2009 | 07:38 PM
benniboi08's Avatar
yup. most definitely the case. bulbs serve as resistors and with one blown out will yield a blinking light that looks like its on speed. good luck
Old Jul 1, 2009 | 09:26 PM
illgangsta9's Avatar
check if u have the right bulbs, make sure none of them are burnt out and make sure u have the right filament ... they make few bulbs with single and dual filaments in the same size
Old Jul 1, 2009 | 10:48 PM
etuhs's Avatar
Old Jul 1, 2009 | 11:57 PM
dambikeracer's Avatar
Have you checked your blinker fluid?
Old Jul 2, 2009 | 09:50 AM
mitsurage's Avatar
ahah very funny.. but yeah were would i add that resistor at before or after the relay?
Old Jul 2, 2009 | 11:20 AM
QwikEVO's Avatar
You should not need a resistor at all.
Check your bulb part numbers.
Old Jul 3, 2009 | 12:49 PM
vegas702evo's Avatar
Originally Posted by etuhs
+1000
