Best radar detector?
Old Nov 9, 2010, 09:13 AM
  #166
CristianRO's Avatar
Beltronics STi Driver works great for me ... 500 retail .. U can pick it up online around 400...
Old Nov 9, 2010, 01:45 PM
  #167
ALSTAR's Avatar
8500 X50 FTW
I have it for about two years now, paid itself off.
Ive also used it overseas and its brillant.
Old Nov 9, 2010, 10:07 PM
  #168
alqubaisi's Avatar
Valentine v1 my opinion great price !
Old Nov 10, 2010, 08:39 AM
  #169
Jmo Evo8's Avatar
Redline. Period
Old Nov 20, 2010, 02:09 AM
  #170
AboodsEvo's Avatar
Guys?? which radar detector is good for overseas asia/middle east laser and radar systems.
They use rear cameras with a blinding flash instead of the front type camera. I need a detector that will warn me ahead of time that cameras and radars are in close proximity. thanks!
Old Nov 20, 2010, 05:54 AM
  #171
Short_Block's Avatar
I have had this since the speaker on my escort passport 8500 crapped out in 2003.
Had it upgraded/updated multiple times. They have amazing customer service!
The unit has paid for itself 4 times over and then some. I would easily have paid double for this knowing what I know now.
Ben
Old Nov 20, 2010, 05:59 AM
  #172
Blue Evo 8's Avatar
Ben
How did you run the wires? I want to install mine the same way
Old Nov 20, 2010, 03:57 PM
  #173
https://www.evolutionm.net/forums/ev...procedure.html
Ben
Old Nov 20, 2010, 05:14 PM
  #174
Blue Evo 8's Avatar
Thanks! You are da man!
Old Nov 20, 2010, 07:15 PM
  #175
Well,
Webguy330 is the Man.
This works perfectly.
It turns on with the key and all you have to do is adjust volume or change settings.
It makes it so easy when you can leave it on all the time.
Ben
Old Nov 20, 2010, 07:26 PM
  #176
stryderlis's Avatar
How come you don't just tab into the fuse box?
Old Nov 20, 2010, 08:20 PM
  #177
Just a matter of preference.
I have never felt that it was the proper execution when I know of other ways.
Typically when I splice, I take a razor blade and slit a wire sheath running parallel to the wire for about an inch. Then I trim out the sheath in between by ringing the razor around the wire on either end of my 1" split being careful not to cut the metal. Then spread the actual metal wire in half (never actually cutting the wire) to where it has a loop and thread my splice wire into the loop, pull tension on the target wire then solder the connection and wrap with electrical tape. If needed I zip-tie my splice wire to the target wire ensuring there will be no future disruption.
Then I take the razor and slit my wrist because I see someone has done a hack job by shoving something into the fuse box that doesn't belong. (If this is what you mean maybe you should find a razor)
If you mean finding a 12v lead by using my volt meter or wiring diagram to determine which wire to splice into. Then I would still have to properly splice into a wire so why not work do it the lazy man's way and sit in the comfort of a Recaro bucket than awkwardly splayed on my back half in the driver's floorboard.
Ben
Old Nov 21, 2010, 07:42 PM
  #178
evo8426's Avatar
i run the valentine 1 maybe 1 out 20 or 30 times i drive my car. i only put it up when i go out for fun-runs. when its up i have it installed above the mirror similar to the one posted above but actually have it completely above the mirror.
Old Nov 21, 2010, 07:52 PM
  #179
I was just worried about the rear antenna not picking up as well with it that high.
They recommend keeping it level centered in the windshield...
I have no idea how it would actually effect things?
Ben
Old Nov 25, 2010, 08:11 PM
  #180
SUSPECTED SCAMMER
ch1215g's Avatar
GET THE V1 best radar detector ever made.
Originally Posted by misfit8
V-1 For me.
Its saved me many times and works perfect threw my tinted windows. (Metal Film). And yes, My windshield is tinted also.
what percent is your windshield tinted? lol off topic sorry
Quick Reply: Best radar detector?
