Alpine iDA-X300
Old Oct 18, 2009 | 08:57 PM
Sideck's Avatar
Alpine iDA-X300
hi.. i don´t know if this forums is for this... but i have a question... i have this head unit (Alpine iDA-X300), and i have a problem with the USB.... already searched in google with no results...
when i add new folders to the USB the stereo won´t recognise the new folders unless i disconnect the battery to reset the stereo... and then the stereo search for new folders again...
i read the manual and i cant find how to reset the BANK again...
maybe this is not the correct place for this, but i hope you can help me...
Old Oct 19, 2009 | 09:55 PM
majestic*'s Avatar
So you disconnect the usb, add folders/songs, reconnect the usb and it won't recognize it until you reset the headunit?
Old Oct 20, 2009 | 12:13 AM
Sideck's Avatar
yes... wont recognize the new folders... still showing the last folders...
if i reset the headunit then yes...
Old Oct 20, 2009 | 08:48 AM
BEISSEN's Avatar
Call Alpine and see what they suggest it might be a bad headunit.I have the X305 I think it is but might be the 300 as well and I dont have issues with it.
Old Oct 20, 2009 | 09:39 AM
majestic*'s Avatar
Hmmm.... that's strange. When you reconnect the usb does it say that it's searching for a few seconds before listing all folders/songs?
It should just pop up... try Alpine support... I haven't seen that issue before and I've installed a lot of these headunits.
Old Oct 21, 2009 | 12:45 AM
Sideck's Avatar
nop.. that is the problem.. never start to search for new files... when i reconnect the usb inmediately start to play the last song played after disconnect the usb...
Old Oct 21, 2009 | 06:04 PM
majestic*'s Avatar
Try changing the source to anything other than usb before you disconnect it... the problem may be that if you are unplugging the usb while it is still reading/playing it may be doing something to the headunit.
If you switch source to tuner and then disconnect the usb and then plug the usb back in... does it make a difference?
Old Nov 1, 2009 | 03:58 PM
StanRS's Avatar
What USB device do you use?
i have iDA-X001 and using USB hdd with it without any problems.
As i've read on the audio forums, there can be some issues with X-series while USB drives, and it depends on HDD manufacturer and model, some of them simply doesn't work with headunit, some of them working with errors and problems.
As tip: i'm using WD 160gb 2,5" external drive, it's going for something like 50$ in stores. No problems with adding folders, files, playback e.t.c.
HDGamer
Jun 29, 2017 09:28 PM
ROOKHOE
Feb 10, 2009 07:14 PM
genma
Aug 28, 2008 12:51 PM
landis507
12
Jul 11, 2008 10:58 AM
turbologist
17
May 2, 2007 07:12 AM
