Head unit problems
Old Nov 14, 2009 | 10:16 AM
Draoz4's Avatar
Head unit problems
to start off i tried looking through the forums and i couldnt find anything
my head unit got stole a while back and they ripped the harness out so all i have is wires left that are different lengths so i used a wiring diagram to wire my head unit but there is a problem the head unit wont save the settings that are set like if i put the time on the head unit it will go back to default when the car is turned off i have no idea what the problem might be can anyone help?
Old Nov 14, 2009 | 03:39 PM
NWEvoViii's Avatar
Check your accessory and your 12v wire. On the radio it should be the red and yellow wire, not sure what it is on the car, but those two wires might be mixed up.
Old Nov 14, 2009 | 04:15 PM
Draoz4's Avatar
hmm ill try it again but last time i tried it it didnt make a difference you think it can be a fuse?
Old Nov 14, 2009 | 05:15 PM
NWEvoViii's Avatar
It does make a difference which wire is hooked up to which power wire on the radio, the radio will still work even if the wires are reversed, but it just wont work properly.
The yellow wire on the radio is your constant wire, meaning it is also your memory wire.
The red wire is your switched accessory wire, so when you turn your key so it goes into accessory, it tells your radio to turn on.
It wouldn't be a fuse because if a fuse was out, your radio wouldn't even turn on at all.
Hope that helps.
Old Nov 19, 2009 | 08:33 AM
Draoz4's Avatar
thx that really helped i fixed it
Old Nov 19, 2009 | 02:24 PM
NWEvoViii's Avatar
Glad to hear your radio is working
Old Nov 19, 2009 | 10:02 PM
evofabulous's Avatar
word. i would have told you the same thing if he didnt do it first. very simple fix imo.
Sosa_bb6
Nov 11, 2019 06:18 PM
Nick22Fire
10
Aug 29, 2012 03:32 PM
earthman
Apr 14, 2009 12:01 PM
LancerOZ Boy
Lancer Troubleshooting
Jun 8, 2006 12:11 PM
nrgaura
Oct 21, 2004 05:28 PM
