Stri Turbo Timer and central locking
Old Dec 29, 2009 | 01:50 AM
uszaty69's Avatar
I've just installed Stri Turbo timer. TT works proper, but after TT installed central lockin dun works with remote (in key). The problem is my alarm works only with remote. When i close driver door by key, works only central locking, no alarm. Strange thing is, when I close passanger door by key, alarm works
Any sugestions how make central lockin work with remote, when Stri TT installed?
I heard it's quite easy, and need few more wires. But i don't know where :/
It's very anoying to close door by passanger site everytime and much more, when I need to use key to open door, when lock is full of ice inside =/
Old Jan 1, 2010 | 08:16 PM
NWEvoViii's Avatar
The turbo timer kinda changed the way things work with the locks. To get everything working properly as it was before, you need to hook up a relay. If you search the forums a bit, you can find a wiring diagram for hooking up a relay or two to an aftermarket alarm. If you're on the stock security system, I don't know how a solution for that. Usually a turbo timer hooked up into a car without an aftermarket alarm will work fine when everything is properly wired up.
