help install radio
Old Feb 13, 2010 | 09:06 PM
timmycat's Avatar
help install radio
anyone know how to install after market radio in evo 8?
Old Feb 14, 2010 | 10:32 AM
timmycat's Avatar
anyone?
Old Feb 14, 2010 | 10:56 AM
darkunitzero's Avatar
buy a harness and match up the colors.
Old Feb 14, 2010 | 10:59 AM
boostedwrx's Avatar
It's just like any other car & super easy - good luck!
Old Feb 14, 2010 | 04:40 PM
timmycat's Avatar
i did and im a lil confused thow cus idk what to do with the wire from the amp because the wire harness only has like 3 wires. what do i connect the wire from the amp to? there are no plugs on the head unit for it and the wire kit didnt come with anything to hook it up with
Old Feb 14, 2010 | 04:49 PM
Psquared's Avatar
Are you talking about the small blue wire that is labeled "remote turn on" for the amp? Or the rca cables..or power...help us help you. Give us a better description.
Old Feb 15, 2010 | 01:04 PM
timmycat's Avatar
these pics should help the, the wire that comes from the amp is the round looking plug thing, that's what idk how to hook up, the radio that's in the car already has plugs for it but the one i wont to put in dose not, what should i do help install radio-2010-02-15-14.39.44.jpg
Old Feb 19, 2010 | 04:15 PM
X91EVO's Avatar
Registered User
what is that round plug do for the amp?
the only plug i seen like that was for an antenna
Old Feb 19, 2010 | 05:30 PM
timmycat's Avatar
i think its the wire for all the speakers not sure how to hook it up to the head unit
Old Feb 20, 2010 | 01:54 PM
timmycat's Avatar
anyone have any suggestions ? still trying to figure it out
Old Feb 23, 2010 | 05:55 PM
X91EVO's Avatar
Registered User
are you talking about the output wires? make sure they are connected to output and not input
Old Mar 2, 2010 | 08:47 AM
Bassicfun's Avatar
If you have the factory amp setup, then you need the correct wiring harness.
Metra 70-7003 (70-7004 is the same as well)
That adapter allows the ground, constant, accessory, dimmer, etc wires to come from the more 'traditional' adapter.
The smaller round plug adapter has RCA low level inputs that need to come from your aftermarket stereo, as well as the blue remote wire.
Most quality head units have a low level out, fronts, rears, subs, etc. so that is simple, if your head unit does not, you'll need basically a line converter to take a speaker level output (from your aftermarket stereo) and turn it into a line level output, to plug into those RCA jacks for that adapter.
If you didn't get the 2nd adapter (small round one) then you'll probably need to pick it up seperately, if it is offered that way, I'm not sure. I just bought mine for $9 shipped for the both adapters.Does that clear up your confusion?
Old Mar 2, 2010 | 01:16 PM
timmycat's Avatar
yes thank you very much
Old Mar 5, 2010 | 03:55 PM
timmycat's Avatar
still stuck the radio i am putting in dose not have the 4 plugs on it so how do i connect the amp wire to it? the wire harness only works for radios with the 4 plugs on it
Old Mar 6, 2010 | 10:41 AM
Bassicfun's Avatar
See the bolded text from my original post for you timmycat.
Something like this should solve your issue.. taking high level (speaker) outputs from your head unit, and turning them into low-level outs.. so basically.. from aftermarket stereo.. to this converter... to the RCA plugs from the above-mentioned harness... to the existing plug that routes to the factory amplifier. Clear as mud?
