I wanna change all stock 4 speakers for my evo 8...Any help guys???
Old Apr 22, 2010 | 12:35 AM
AboodsEvo's Avatar
Question I wanna change all stock 4 speakers for my evo 8...Any help guys???
I wanted to swap my OE speakers. I heard 6.5" would fit but it doesn't really.
Can I get any help guys. Whats the best swap youve made plus speaker specs. Thanks
Old Apr 22, 2010 | 05:09 AM
FJF's Avatar
FJF
Try reading some of the other threads. Good luck.
Old Apr 22, 2010 | 08:10 AM
mressler12's Avatar
You need 6.5" speaker plates. You can get them on ebay. http://cgi.ebay.com/6-Speaker-Adapte...item4a99f45d7f
Old Apr 22, 2010 | 08:14 AM
dahuii77's Avatar
zip ties bro and u good to go!!!!!!!!!!!!!!!!!
Old Apr 28, 2010 | 06:31 AM
EvoIX2240's Avatar
I have 6 1/2 for my front and rears. I did not have to use plates. I have Alpine Type S units. I'm not sure why you are having problems. Some 6 1/2's run slightly oversized though, could be labeled a 6 3/4. Look for something like that.
Old Apr 28, 2010 | 03:36 PM
DSM Jim's Avatar
I just bought poll 6.5's and the rears dont fit, im thinking of either rigging it to work or buying the plates that mressler gave a link to
Old Apr 28, 2010 | 04:01 PM
pheonix991's Avatar
I had some Image Dynamics CTX65CS's in my legacy. They were deep, not sure if they will fit in an evo. They were super clear pushing 100wrms each.
Old Apr 28, 2010 | 04:03 PM
Evo8ux2's Avatar
just buy the plates youll be much happier with the results
Old Apr 28, 2010 | 05:34 PM
FJF's Avatar
FJF
Or, leave out the rears and get a better sounding system as a result.
Old Apr 30, 2010 | 11:39 PM
AboodsEvo's Avatar
I think havin a surround type is much better than just two in front. Yeah I think those ebay plates are the best. Thanks guys
Old May 1, 2010 | 05:44 AM
FJF's Avatar
FJF
A surround matrix takes the common information in the 2 stereo channels, strips it of the frequency extremes, throws it out of phase, adds time delay, lowers its amplitude and only then does the sound come out of the rear speakers. That's not what happens in a car system, is it? Stereo means 2 channels.
Old May 1, 2010 | 12:29 PM
shuttlegoose's Avatar
different speakers can worth with the stock head unit correct? Im not really big into putting a "system" in my car but a little better replacement speakers would be nice.
Old May 1, 2010 | 01:16 PM
FJF's Avatar
FJF
No, not really. You'd be much better off upgrading the HU and keeping the stock speakers.
Old May 2, 2010 | 02:31 PM
evo_you_know's Avatar
First off let me start by saying that I use to install auto systems for a living for two different big chain stores. I have over five years doing car audio and alarms. with that said I will tell you that swapping out your factory speakers with good quality speakers will help a lot with sound. but if you install the best speakers you can find with "zip ties" you may not get sound that is any better than stock and may sound worse. I have seen installs with product costing over 2,000 not sound any better than stock just because it was not installed correctly.
for a speaker to be installed correctly you need it to be mounted solid so it dont vibrate also it needs to be sealed so that the sound waves from the back of the speaker do not come around the speaker to the front side. so use spacers if the speaker dont seal to the rear deck or the door panel. you could also trim the mounting hole bigger so the speaker will fit better.
Old May 2, 2010 | 04:53 PM
FJF's Avatar
FJF
Originally Posted by evo_you_know
....with that said I will tell you that swapping out your factory speakers with good quality speakers will help a lot with sound.
In an Evo that's moving? When the car is standing still, sure.
...but if you install the best speakers you can find with "zip ties" you may not get sound that is any better than stock and may sound worse.
I think we have this part figured out.
