EVO 8 cuts out / dies for no reason
Old May 11, 2010 | 06:30 PM
MPEARSALL's Avatar
Every now and then my evo decides to just lose power. I have changed the ignition switch out and that seemed to help a bit, but the other day i was in a drive through car wash and my evo just died and wouldn't start so i waited till the car wash ended got out and pushed my car out of the wash bay and when i got back in the car had power going to it. If you have any ideas please let me know because its becoming a hassle / embarassing problem.
Old May 11, 2010 | 06:37 PM
TurboTim06's Avatar
is your battery good? check the terminals yet? Loose? Any corrosion?....check for a bad or corroded ground?...
Old May 11, 2010 | 06:55 PM
MPEARSALL's Avatar
no man the battery is good and so are the terminals its weird i will put in the key and the ding will go off for the door being open but when i close the door and turn it to acc or to on the gauges dont work or anything and it wont start.
Old May 11, 2010 | 06:58 PM
bigturboevo80's Avatar
check for something electrical that is exposed. And where the car gets wet in the engine bay after a car wash.
Old May 12, 2010 | 04:19 PM
MPEARSALL's Avatar
It was dying and cutting out before i washed it though. It has done this several times.
Old May 17, 2010 | 04:34 PM
warstang27's Avatar
my best bet is the starter solenoid bolt is loose, my wifes elantra did the same thing, confused the crap out of me till I found that.
Old May 17, 2010 | 06:24 PM
1sxyrxy's Avatar
check your main power relay
WangMan
18
May 16, 2006 06:28 AM
herbal77
Jul 21, 2005 05:39 PM
plokivos
Dec 31, 2004 08:20 PM
