Headunit problems w/ mini battery!?!?
Old May 12, 2010 | 01:30 AM
car852's Avatar
Ever since I installed my mini battery, my headunit hasn't been able to read SD cards, USB drives, or even CDs for that matter. I just use auxilary for now.
Any one else have that problem?
Or have any ideas on how to fix the problem?
Old May 12, 2010 | 04:17 AM
kristokes's Avatar
Try putting the old battery back in and see if your head unit still acts up then take it from there. Whether it's a battery or a headunit related issue.
Old May 12, 2010 | 06:37 PM
highpockets's Avatar
No headunit problems but at idle,cranking the stereo/sub will kill the car ! This is a PC680 battery,BTW.
Old May 12, 2010 | 07:47 PM
Routybouty's Avatar
Mini batteries and large stereos don't mix well. OP, try post #2, something doesn't add up here, that doesn't make any sense.
It doesn't work with the car running either?
Old May 12, 2010 | 08:36 PM
mogace's Avatar
First rule of troubleshooting, work your way backwards.lol If it still doesn't work, try just leaving the radio disconnected for a few minutes. That should reset it. (You can bypass this is the radio has a reset button on it. Usually behind the faceplate)
Old May 14, 2010 | 06:19 PM
fishie36's Avatar
Try resetting the headunit, often times there will be a small reset hole behind the faceplate that you can stick a pin into.
EvoJoeIX
Mar 19, 2010 01:30 PM
Vibrant
Oct 29, 2008 06:07 PM
fastassfourdoor
Dec 8, 2007 05:27 AM
Evo23IG
39
Oct 28, 2007 03:26 PM
Lox1985
Apr 4, 2007 10:38 AM
