evo ix ecu wont read/scan/write
Old Sep 20, 2010 | 12:45 PM
_mcjonnyp's Avatar
Question evo ix ecu wont read/scan/write
So I've been messing with this for a few weeks now with no real results..
The problem - whenever I plug anything into the obd2 port - tactrix or any obd2 scanner - nothing will recognize the car.
I have updated all the drivers for the tactrix and the battery is showing 12 volts.
No fuses are blown, all the obd wires have continuity to the ecu, and none are sparking to ground on a dialectic tester. I have even tried hooking up a new ecu and nothing will read.
Hopefully someone can help me out, because I'm totally stumped on this issue
Thanks in advance!
Old Sep 21, 2010 | 07:15 AM
_mcjonnyp's Avatar
anyone
Old Sep 23, 2010 | 10:10 AM
artisticspawn's Avatar
I just purchased a tactrix cable from an Evom member today and before I did so I was reading that it does depend on the cable you get whether it will work with you car or not. In your signature you did not list your EVO model and therefore the best I can do is point you to where I read about the cable version bein important and possibly your issue.
http://evoscan.com/mitsubishi-subaru...bd2-can-cables
Old Sep 23, 2010 | 04:42 PM
_mcjonnyp's Avatar
the car will not connect to any obd2 scanner either, like advance auto parts scanners etc..
The issue is not the cable
Old Sep 25, 2010 | 07:53 AM
_mcjonnyp's Avatar
bump
Old Sep 29, 2010 | 09:07 PM
_mcjonnyp's Avatar
update...
constant 12v pin on the ecu was only showing 9v.. hardwired it to another 12v source and still no luck.........................
anyone had this issue before?
Old Oct 16, 2010 | 07:39 AM
_mcjonnyp's Avatar
wow.. ended up being one of the terminals on the obd connector was bent open, not making a good connection with the cable..
man I feel like a noob.. mods can move this to the super noob section lol
9!'clipseDOHC
Jun 11, 2015 06:47 PM
harshadura
Jun 1, 2014 05:55 PM
monkeyevo
Jul 20, 2011 11:09 PM
boosted91t
Jan 24, 2011 09:46 AM
raywong
Oct 26, 2003 06:48 AM
