Anyone ever added a 2nd battery under the hood?
Old Mar 28, 2011 | 03:05 PM
cstylez52's Avatar
I was wondering if anyone has ever added a 2nd battery under the hood and where at? Reason I am asking is because I put a big stereo system in the Evo and need a 2nd battery but have no room in the trunk because of all the fiberglass work for the stereo equipment.
Old Mar 28, 2011 | 05:11 PM
awdordie's Avatar
not to be rude, but most people here on evom don't install huge stereo equipment in their evos. Im guessing yours must be for shows and sound competitions tho? Good luck installing another battery under the hood as there is little room for the factory one already in there. You could always pull the back seats to get behind the fiberglass into the trunk through the cabin area to mount another battery.
Old Mar 28, 2011 | 05:44 PM
CJ2X's Avatar
The only place I can think you could place a small battery is behind the back seats where your rear speakers are; Right under the rear windshield.
Old Mar 28, 2011 | 05:45 PM
cstylez52's Avatar
No its not for shows it is for my 15 yoa sons 1st car. When you can have a bad azz car with a bad azz system in it, why not. When we get it done we will be sure to post pics on here.
Old Mar 28, 2011 | 05:46 PM
chaotichoax's Avatar
facepalm...15 years old? evo? not a good mix
Old Mar 28, 2011 | 05:51 PM
KX250Fmotoracer's Avatar
Jesus christ. Hope you dont have to bury your son
Old Mar 28, 2011 | 06:41 PM
Raistlin's Avatar
+1
I admit some teens are pretty responsible, but they are truly very few and even then they do things they should not do.
I hope you everything works out for you, seen too many wrecked cars of all types too not have concern about this mixture.
Old Mar 28, 2011 | 06:43 PM
Ramen_Noodle's Avatar
Let's keep this thread on topic please. This thread is not about his sons age, it's about the sound system he wants to put in the car.
Old Mar 28, 2011 | 06:46 PM
camoevox's Avatar
possibly in place of the spare kenetic makes some awsoe stereo batteries of diffrent sizes
Old Mar 28, 2011 | 09:29 PM
EVO8emUp's Avatar
facepalm...Monster stereo that would require an additional battery and glass work in the trunk? evo? not a good mix
Fixed.
You should probably direct him to this section then......
https://www.evolutionm.net/forums/ev...-security-180/
Old Mar 28, 2011 | 09:44 PM
03bbyevo's Avatar
somuchfail
Old Mar 28, 2011 | 09:48 PM
Hearts_Fitment's Avatar
Originally Posted by 03bbyevo
somuchfail
*Like*
I'd suggest under the seats. You could easily stack some small Kinetik batteries under there. Plenty of room for amps so two batteries shouldn't be an issue. Wire routing would be a nightmare, however.
Old Mar 28, 2011 | 09:53 PM
mrboost05's Avatar
make a batt tray on the drivers side weld it to the frame easy to do on the 03-04 evos the acd might be in the way on the 05-06 ive did this on 3 cars i mean mini batt btw a stock evo batt would not fit i would think good luck.
Old Mar 29, 2011 | 05:49 AM
FJF's Avatar
FJF
Is all the equipment purchased and the system in place? I'm asking, because a big system doesn't have to use a second battery, if configured with low current draw in mind.
Old Mar 29, 2011 | 01:26 PM
X91EVO's Avatar
Registered User
I would just go bigger alternator or maybe you could fit another battery in the trunk where the stock reservoir for washer fluid is
