car start but die after 2 second...
Subscribe
Mar 13, 2012 | 01:15 PM
hi guys
i just bought my evo and i have a big trouble with it....when i start the car,if i dont give some gas he die. i can ride with the car... but under 3000 rpm he is bucking and if i dont give some gas, he dies.
i check all the wire from the maf and they are ok.
when i unplug the maf,the car dont die and i can drive it to 4500 rpm...safe mode i think.
i found something weird, i dont have a leak but if i unplug a piping at half, the car dont die on idle....
if the map sensor is unplug...that change nothing...
i chek the iac motor and everything seem like normal( the teeth are still there) and when i start the car, the motor go up.
i also try something,i take the maf out of the intake pipe, i let the plug on it and i put it on the shock tower, then i start the car and he dont die. but when i shoot some wind on it,the car immediately die.
im not a mechanic but if you can tell me something to chek i can do it.
and im sorry for my english...im french.
the car have 75000 mile on it, it have a 3 inche turboback exhaust,a hks bov and a aftermarket intake pipe.everything else is stock.
forgot to tell that when i plug the maf and go ride the car, until im over 3000 rpm the car run great.
i have no chek engine. no code.
your help would be very appreciated.
thank you
Reply 0
Mar 13, 2012 | 02:18 PM
little update!!
i chek the ohmg resistance on the iac motor and it show this:
pin 1-2= 29.5 ohmg
pin 2-3= 29.5 ohmg
pin 3-4= nothing
pin 4-5= 29.5 ohmg
pin 5-6= 29.5 ohmg
i think i read that its suppose to have between 27 to 33 ohgm on every bridge on these pin.... so that means that the iac is broken event if i see it move when i start the car and i have it in my hand. waiting for the new iac...uptade after i try it.
Reply 0
Mar 13, 2012 | 02:21 PM
check all ur vaccum lines to the intake manifold. if not u might need to adjust the idle screw on the back of the thottle body good luck!
Reply 0
Mar 24, 2012 | 12:54 PM
pin 3-4= nothing... there you go
Fix? any update
Reply 0
Mar 25, 2012 | 04:38 PM
i dont have the new iac....im waiting for it to arrive....sure i will make a update as soon as i can!!!
Reply 0
Mar 25, 2012 | 06:55 PM
Sounds similar to the problem I had before I replaced my iacv. My car would have trouble staying alive once I started it. Had to give it gas to keep it from stalling out. If I disconnected the battery and then reconnected it, the car would idle normally, which was odd. It would stall after I hit boost and come to a stop in neutral. Then the start up problems would return.
I checked the spark plugs, coils, and even my MAF too. All were fine. So I replaced the iacv with a new one and now the car runs perfect. I hope that's your problem.
old vs. new iacv
Reply 0
Mar 27, 2012 | 05:23 PM
i change the iac and its not resolving the problem...i found something really weird.if i give gas in neutral, to 5000 rpm, the car drop to 4000 and go back to 5000 them drop to 4000 .....but i dont move my feet on the gas.... i dont understand why....any idea??? nobody already have this trouble???
Reply 0
Mar 27, 2012 | 06:29 PM
when its running funny... turn on the ac and see if it dies... well at a rate faster then usual
Reply 0
Subscribe
