HELP! No battery or engine harness with the windows Dow
Old Jul 26, 2013 | 04:11 PM
Darkn3s's Avatar
Well like the title says I removed the battery and entire engine harness with fuse box... Does any one have a easy way of putting up the windows without putting all that back in the car? They are powered windows btw... In cabin harness and fuse box still intact
Old Jul 28, 2013 | 02:35 PM
Darkn3s's Avatar
Could I just add 12v somewhere and call it a day?
Old Jul 30, 2013 | 09:57 AM
intj123's Avatar
Yea you got the right idea, there should be a way to just apply 12V direct though and just power the window you might even want to bypass the up/down switch, if you can just disconnect the window motor connector you can probably apply 12V to it from there, if you want to move it the opposite direction up/down, and if there is only 1 positive and 1 negative connection, then simply reverse the polarity for opposite direction. Honestly I'm too lazy to go look at the electrical diagram, because it doesn't have a table of contents I have to manually sift through hundreds of pages to find your circuit. If you disconnect the motor and power it like so it shouldn't harm any other circuit that may be in line like the window timer.
Old Aug 19, 2013 | 07:59 AM
Darkn3s's Avatar
figured it out.. pretty simple for the fronts
- you have to pull the window switch panel up in the front doors
-unplug the harness
-look for the two wires running to the window motor (green & blue)
-apply 12v to one wire and ground to the next (flip it to make the window go opposite way
**all doors have same colored wires
rear panels have to be removed to access rear window switch***
ihockey1
Dec 15, 2013 05:22 AM
Dan@Assaultech
55
May 29, 2012 09:24 AM
XdsEVO8X
For Sale - Part Outs
10
Nov 7, 2010 04:38 PM
2006MRevo
50
May 17, 2010 06:48 PM
aspensvt16
Feb 25, 2008 02:50 AM
