Custom dash piece (for iPad)
I hated the red stock ones so I went with those.
Then I went through and replaced all the other little bulbs with blue LEDs. You can see the ignition ring LED in this pic as well as the HVAC. I also swapped the fog light / headlight leveler / ACD bulbs.
I bought the 3mm ones, work great, but I had to bend the connectors to go through the hole and touch the connectors on the backside of the board - then soldered them in.
You have to open up the switch housing.
For the HVAC ones it is size 74 bulbs - If you do LED ones, I recommend getting ones that point sideways, if you don't they wont illuminate properly - If you have a place you can purchase LED lights near you, I would recommend buying a few different ones and trying them - I bought i believe 5 different types before I found the ones I liked (which I got off ebay). Also note: Some might look purple vs blue.. so that's why I recommend trying them
And I also have the prosport gauges in blue.
With the size of the iPad to bezel, I would have to make a wider pan so I could slide the iPad onto the connector on the left, just wasn't.. really enough room. If I took the time and planned a charger into it it would probably work.
The ignition Keyring, Ashtray, and Cigarette lighter are also the Size 74
These are the bulbs I use (http://www.ebay.com/itm/261136245244...S:3160&vxp=mtr)
The only problem with those ones, is the part that slides into the connector was smaller.. so it wasnt a snug fit - I had to build up a small mountain of solder in order for it to wedge in snug - other than that, works great.
doncarbone
45
Feb 14, 2016 12:03 AM
