evo 9 headlight adjust all by itself
Old Jan 25, 2014 | 11:59 PM
frank-n-stein's Avatar
hey guys first off I got a 06 evo 9 SE...recently my right headlight has decided to adjust itself, you can hear the leveler motor going crazy, up and down none stop. left head light is perfectly fine...anybody else have the same problem or know how to fix it. thanks in advance
Old Jan 26, 2014 | 09:52 AM
Rspence21's Avatar
wish I could be more help to you, but im somewhat in a similar boat...mine just plain stopped working. when I turn the wheel on my dash, nothing happens. all wires, plugs and fuses involved with the headlights are fine...im at a complete loss myself...
Old Jan 29, 2014 | 11:33 AM
jtcarstens's Avatar
My right headlight does the exact same. if i put it on the setting that points it up the highest it never stops but if i put it 1 lower it stops adjusting itself normally, its like it can't quite pull itself all the way up.
Old Mar 8, 2014 | 12:37 PM
740 Turbo Brick's Avatar
I have the same problem with my 8, but its the driver side headlight. If you put it all the way up, the headlight constantly aims, one lower than that and it stays level. The only way I could get it to stop was to cycle it thru all of the positions and go back to all the way up, and it would stop moving then, but if I turned the headlights on and off it would readjust and do it all over again.
You can try my "Solution", which was to cycle it through the levels, go back up, and unplug the leveler behind the kick panel when its all the way up. No more moving headlights and I very rarely ever need to adjust them so it works for me.
Rome97
May 7, 2017 10:29 PM
OneCrzyEvo21
May 24, 2016 10:57 PM
Aniel
May 11, 2016 09:49 AM
Rookie05r1
Nov 15, 2015 09:23 AM
chargespeedMR
Sep 19, 2008 06:12 AM
