Keyless Entry Stopped Working?
Old Dec 15, 2015 | 06:22 PM
ismkv8s's Avatar
Alarms are a waste of money anyway..if someone is going to steal a car and they know what they are doing alarm is just an obstacle. I woulnd't bother installing a new one.
Old Dec 15, 2015 | 08:20 PM
barneyb's Avatar
From your description I still suspect the actuator. You will soon know - once the actuator starts acting up it soon fails completely. If that is true you are pulling a working alarm. Maybe hold off for a few days before pulling the alarm or check for the door signal.
Old Dec 16, 2015 | 02:14 AM
7rrivera7's Avatar
Barneyb you might be right. If the actuator is not sending the signal to the alarm, it obviously won't disarm.
What is the procedure for testing the actuator?
Old Dec 16, 2015 | 02:31 PM
barneyb's Avatar
Read thru this post first. Notice the contacts in the lid of the actuator covered with grease. This is where the locked and unlocked signal originates.
https://www.evolutionm.net/forums/mi...or-needed.html
Old Dec 16, 2015 | 08:14 PM
Biggiesacks's Avatar
TBH an alarm set up the way OP's is is kinda worthless anyway. Anyone can pop the door handle with a screwdriver and have access to rod that operates the lock/actuator and disarm the alarm. This is a common method of breaking into an evo as well so its basically killing two birds with one stone for the thief. What you want is a system that is isolated form the factory system (to disarm anyway) so as to provide an additional obstacle.
Old Dec 17, 2015 | 02:40 AM
7rrivera7's Avatar
Excellent point!
Old Dec 19, 2015 | 04:26 AM
7rrivera7's Avatar
Any suggestions on a common alarm system for our cars or is Viper a good choice?
Old Dec 19, 2015 | 12:20 PM
I've installed countless vipers, never had any come back with problems. That being said the remotes use to be pretty fragile, not something you could keep on your keyring and expect it to last forever. I have been out of the game for almost a decade though so things may have changed. If you look though, Directed Electronics makes like 3/4 of the aftermarket alarms, just under different brand names. Unless you live in alaska or something i wouldn't bother with the remote starting stuff, not worth the risks if you ask me. Hack two wires on a remote start system and a criminal has just turned it into a hot wire aiding system.
wazmunstr
Nov 7, 2017 08:46 PM
Mfell
Lancer How Tos / Installations
Nov 24, 2015 06:23 PM
katchup
Aug 2, 2009 11:11 AM
white venom
Jan 9, 2007 09:08 AM
Lancestuh817
Lancer Troubleshooting
May 4, 2005 11:34 PM
