Ignition Issue, Delayed Start
Old Apr 22, 2016 | 11:27 AM
[GBU]Moon's Avatar
I assume this is ignition but when I get in my car and turn the car to start position, nothing happens. Lights don't dim, no click sound, literally nothing happens. I can usually try again 3-5 times then BAM it works. Does this sound like an ignition problem? It's been this way for ~10 months, it doesn't really bother me unless I'm running late but I might sell my car soon and I don't want to explain that to any perspective buyers, especially if it can be easily fixed.
2003 Evolution VIII with 154,000 miles.
Old Apr 22, 2016 | 11:30 AM
detroit pistins's Avatar
https://www.evolutionm.net/forums/ev...ied-fixed.html
Old May 3, 2016 | 01:41 PM
[GBU]Moon's Avatar
Originally Posted by detroit pistins
Thanks but this describes a click sound. I don't hear anything when I turn the key the first 3-5 times. This is however simple enough, I'll try it for kicks. Right now I'm waiting on a new thermostat. Over 150K miles blues.
Old May 3, 2016 | 03:37 PM
edsct9a's Avatar
In reference to the linked thread, mine wouldn't make the click sound. To test this, I removed the panels behind the steering wheel and while holding the key to start, I would move the part on the left and it would start.
Old May 3, 2016 | 03:47 PM
FTONOOB's Avatar
Is the trigger wire (to solenoid) getting anything when you crank/turn key?
Old May 3, 2016 | 06:19 PM
ISPEVO8's Avatar
I had this issue on my car a while back where I would have to turn my key fast enough to beat the switch from moving. the above fix solved my issue. other things to look for is corrosion on your signal wire on your starter as well as the positive terminal on your battery. take apart the positive terminal and clean up the connectors and see if that helps.
jbake_11
May 21, 2017 12:23 PM
turbocheese
Apr 14, 2016 04:46 PM
turbocheese
Apr 13, 2016 11:08 PM
