Stock ECU Transistors
Old Sep 13, 2016 | 06:43 PM
Biggiesacks's Avatar
I have been on and off toying around with different methods of doing the fuel pump hard wire, or second fuel pump addition. Traditionally this is done with a hobb switch to trigger the new relay, but I wanted to try and explore a way to drive the bypass / second relay from the ECU more directly. I have been posting about it in mrfreds rewire howto here: https://www.evolutionm.net/forums/ev...e-circuit.html
but i figured that information might get buried so i thought i would post it here. I have done some minor reverse engineering on the Stock ECU and have found that it uses Fuji Electronic F5033 Power mosfets to trigger the various relays in the car. Circled in Red is the one that triggers the high voltage relay in the fuel pump circuit
These mosfets have a rating of 1000 milliamps of continuous current. The Datasheet can be found here:
http://datasheet.octopart.com/F5033-...t-10902086.pdf
The typical 30amp bosch style relay draws around 130 milliamps @ 12volts to trigger. So if you wanted the ecu to trigger additional relays on an existing control circuit there should be plenty of headroom to do that without risking any damage to the ECU (when wired properly).
RallySport9
Sep 9, 2013 11:12 AM
myevo8urcar
E85 / Ethanol
27
Oct 6, 2009 11:06 PM
GTVEVO
Jun 4, 2006 06:59 PM
nemesys6
Turbotrix Racing - Edison, NJ
May 17, 2006 12:11 PM
