small battery help
Old Feb 1, 2018, 01:03 PM
Aby@MIL.SPEC's Avatar
small battery help
Hello,
I am looking to move away from my pc680 battery
I see people say miata batteries = prefer post's on other ends
or
grp 51 batteries = costco/interstate grp 51 is too tall, they measure ~8.75"
nobody claims to have a miata battery in-store locally when i call to measure up.
what make/model miata batteries are you using?
any chance that someone can i.d. the battery in this pic?
i dont mind making a battery tray & not interested in moving the battery to the trunk either.
Old Feb 1, 2018, 01:13 PM
Received 1,384 Likes on 1,317 Posts
Hi Aby
We have a couple of good battery threads in the motorsports section. Heres a recent one regarding Lithium's
BTW, Been on the PC680 for years & works for me
https://www.evolutionm.net/forums/mo...t-battery.html
Joe
Is2scooby (Aug 7, 2018)
Old Feb 1, 2018, 02:09 PM
Tuxevo's Avatar
This little battery is tough as nails. I had one for 5 years. Let it die over and over and it kicked butt until it didnt. I replaced it with an Odessy, treated it the same and it took a crap in 8 months. Went back to the Shuriken, still let it die all the time and it's still working great.
http://www.streettunedmotorsports.co...ll_battery.htm
Old Feb 1, 2018, 02:54 PM
thanks for the links
Old Feb 1, 2018, 03:05 PM
4b11slayer's Avatar
I reccomend a ETS Battery. Same size as odyssey pc680 but has about 300 more cca
Old Feb 2, 2018, 08:44 AM
thanks 4b11
how long have you been using the ets battery for?
my pc680 began struggling after 2 or 3 years, on really cold mornings on e85
Old Feb 2, 2018, 09:01 AM
4b11slayer's Avatar
Originally Posted by Aby@MIL.SPEC
thanks 4b11
Ive only had it for about a month or two. My odyssey lasted over 3 years but towards the end of its life it was garbage. It left me stranded 1 too many times so i contacted ets and they recommended there battery.
So far so good. i live in SOCAL and i am on e85 also but as you know we dont really have a winter here.
ETS: 480 cca
Odyssey: 170 cca
So the ets pushes out 310 more cca.
The only downfall is its a little heavier but........
Oh and ets is only 99 bucks.
Old Feb 2, 2018, 09:15 AM
Abacus's Avatar
I also had a group 51 battery and my car wasn't too happy about starting on the Infinity. I have a EFI battery tray that I trimmed to work with ETS short route piping. You may not have to trim it if you are using an open filter. I moved to a Odyssey 1100 and things got much better on the Infinity .Now with the MoTec it starts like a stock car.
https://www.evolutionm.net/forums/pr...-2themoon.html
pics of battery /tray on post 4
Old Feb 2, 2018, 09:19 AM
kyoo's Avatar
i'm using the shorai lithium iron, as is heel2toe. 5lbs. huge cca. no issues here, but my car is always on a trickle
Old Feb 2, 2018, 02:09 PM
link please?
Old Feb 2, 2018, 02:39 PM
Bladey's Avatar
Using a full river Hc20, extremely good battery will do 680CCA for 5 seconds. And flat rated to 310cca after that time. Only issue is they tend to go flat rather quick, but a decent 10AMP charger kicks her to life easy as.
Old Feb 2, 2018, 03:04 PM
heel2toe's Avatar
link please?
This is the one: https://shoraipower.com/lfx36l3-bs12-p130
I've had great success with that battery for almost 4 years now. Also, Shorai as a company is awesome to deal with so another reason to support them and buy their stuff.
5# and 540CCA. Think it cost me about $260 and then you just need some terminals which you can probably reuse from your current mini battery if you have one. As for the battery tray I just hacked up the OEM one but even that isnt needed.
Old Feb 2, 2018, 06:29 PM
kyoo's Avatar
they'll come with terminals, cushion material. i just had to buy one tie down, which i purchased stm's as it was the only one thin enough. then reused oem mounting tray and tie downs because lazy because cheap
Attachment 324916
Aby@MIL.SPEC (Feb 3, 2018)
Old Feb 4, 2018, 09:09 PM
JohnnyTSi's Avatar
Hello,
Best thing I ever did for cold weather starts was step away from the mini-battery.
This is the Miata battery I used:
Duralast Gold 8AMU1R
I fabbed up my own battery tray, fits with the ETS short route upper IC.
John-
Old Feb 9, 2018, 08:32 PM
ylee0710's Avatar
Using the ETS small battery kit for 2 years. Starts up every time no problem. Barely driven
Quick Reply: small battery help
