Need Help Identifying Cable Size
Old Dec 18, 2021 | 06:23 AM
Jrah2987's Avatar
Veteran: Air Force
Does anyone happen to know the sizes of these 2 cables, or at least what size would be acceptable to splice to? They originally ran to the fusible link on the Evo 8 battery, but I need to extend them a bit to reach a relocation bracket I bought. Picture for reference; one is black/blue the other is white/red:
Thanks in advance.
Old Dec 18, 2021 | 06:20 PM
slocho's Avatar
Rule of thumb for electrical is you can always go up a size, never down. Not sure what the size because for some reason i cant see the picture. But if its a battery cable, probably would be 4 gauge or maybe a 2 gauge. I always use solder and heat shrink when making a new cable never leaving exposed wire. Most auto parts stores will sell you quality cable by the foot or in a roll.
Old Dec 19, 2021 | 11:40 AM
Jrah2987's Avatar
Veteran: Air Force
Thanks for the insight. I think I'll try using 4 gauge if nobody seems to know for sure, since the main battery cable is 2 gauge, and it doesn't appear to be as big.
I believe one cable runs to the alternator, not sure where the other goes. Thanks again.
Old Dec 19, 2021 | 11:52 AM
slocho's Avatar
I just re-read my post and i wanted to clarify one thing that may be confusing, in the case you didn't know.
With electrical wires, the higher the gauge number, the smaller the wire. It doesnt make sense lol but thats what someone decided to call it. For example, a 10 gauge wire is smaller than an 8 gauge wire. 8 gauge smaller than a 6 gauge so on and so forth.
So if the cable is 4 gauge, a suitable replacement would be 2 gauge. Smaller in "number" but bigger in actual size of the cable. Hope that clears it up.
Old Dec 21, 2021 | 04:15 PM
Jrah2987's Avatar
Veteran: Air Force
I understood, thanks for clarifying, though. Ordered some new cables, thanks again.
myearwood173
Sep 26, 2010 01:15 PM
raiceboi697
Northwest Region
11
Sep 16, 2007 07:37 AM
Evo478
Aug 5, 2006 02:19 PM
Spooldyou
Apr 18, 2006 10:40 AM
mystic_evo
Nov 1, 2003 01:44 PM
