How do I get my Turbo to hold consistent boost levels?
Old Sep 24, 2004 | 07:43 PM
Evo VIII 4o1's Avatar
I heard that the 2003 EVO holds boost at 19psi and levels down to 16psi at 5500RPMs. How do I make it stay consistent throughout the powerband? Will it damage my engine?
Old Sep 24, 2004 | 07:47 PM
SurfguruJon311's Avatar
Get a mbc, this seems to help alot with tapering issues. Youll probably damage your turbo if you go anywhere past 22 psi but should be safe anywhere below that.
Old Sep 24, 2004 | 08:09 PM
tokeone's Avatar
a new bov will also be needed
Old Sep 24, 2004 | 08:15 PM
jansolo's Avatar
WORKS P2 reflash also holds boost consistently till redline.
Old Sep 24, 2004 | 08:18 PM
eve-slow's Avatar
I suggest a Greddy Profec-B Spec 1. Holds boost amazing and is user friendly. Also, a reflash would be good.
Old Sep 25, 2004 | 01:03 PM
vletnguyen's Avatar
i have mbc, flash and bov.. i tired it on oem bov (non-mr) and it leaks. with my aftermarket it holds somewhat.. spikes 20 then 18-19 at redline
Old Sep 25, 2004 | 01:13 PM
Rez90's Avatar
Get a manual boost controller. $50 at www.turbotrix.com
